查看: 10247|回复: 5
[求助] homekit隔天就断开
发表于 2020-9-8 11:20:16 | 显示全部楼层 |阅读模式
docker里安装的HomeAssistant,一切正常,隔个两三天HomeKit就连接不上HomeAssistant要重启才能恢复正常。持续好几个月了,找不到解决方法,发帖求助!
报错时间貌似跟路由重新拨号差不多一个时期,不是重新拨号导致断开无法在连接上,但是网页或者HomeAssistant APP都是能正常控制的。
报错日志如下:
2020-09-08 09:59:01 WARNING (MainThread) [homeassistant.components.switch] Platform xiaomi_miio not ready yet. Retrying in 180 seconds.
2020-09-08 10:02:06 WARNING (MainThread) [homeassistant.components.switch] Platform xiaomi_miio not ready yet. Retrying in 180 seconds.
2020-09-08 10:02:54 WARNING (zeroconf-ServiceBrowser__dkapi._tcp.local.-_viziocast._tcp.local.-_miio._udp.local.-_printer._tcp.local.-_axis-video._tcp.local.-_daap._tcp.local.-_wled._tcp.local.-_ipp._tcp.local.-_googlecast._tcp.local.-_api._udp.local.-_Volumio._tcp.local.-_bond._tcp.local.-_plugwise._tcp.local.-_esphomelib._tcp.local.-_hap._tcp.local.-_elg._tcp.local.-_spotify-connect._tcp.local.-_nut._tcp.local.-_ipps._tcp.local._140384940452640) [zeroconf] Error sending through socket 13
  File "/usr/local/lib/python3.7/site-packages/zeroconf/__init__.py", line 2834, in send
    bytes_sent = s.sendto(packet, 0, (real_addr, port))
OSError: [Errno 101] Network unreachable
2020-09-08 10:05:11 WARNING (MainThread) [homeassistant.components.switch] Platform xiaomi_miio not ready yet. Retrying in 180 seconds.
2020-09-08 10:08:16 WARNING (MainThread) [homeassistant.components.switch] Platform xiaomi_miio not ready yet. Retrying in 180 seconds.
2020-09-08 10:11:21 WARNING (MainThread) [homeassistant.components.switch] Platform xiaomi_miio not ready yet. Retrying in 180 seconds.
2020-09-08 10:14:26 WARNING (MainThread) [homeassistant.components.switch] Platform xiaomi_miio not ready yet. Retrying in 180 seconds.
2020-09-08 10:17:31 WARNING (MainThread) [homeassistant.components.switch] Platform xiaomi_miio not ready yet. Retrying in 180 seconds.
发表于 2020-9-8 12:33:50 | 显示全部楼层
看你这个信息是miio有问题,插座本身断开了,和homekit没关系
 楼主| 发表于 2020-9-8 17:54:10 | 显示全部楼层
测试了一下,是路由重新拨号后就出出现这个问题!
说下环境:openwrt里的docker安装hass,WAN口拨号上网。
发表于 2020-9-10 20:36:11 | 显示全部楼层
说下环境:openwrt里的docker安装hass,WAN口拨号上网。 ...
  那用树莓派跑docker吧~
 楼主| 发表于 2020-9-12 09:48:15 | 显示全部楼层
duchenpaul 发表于 2020-9-10 20:36
那用树莓派跑docker吧~
一个软路由在跑,不想加太多设备了。
发表于 2020-9-14 10:55:45 | 显示全部楼层
打酱油 发表于 2020-9-12 09:48
一个软路由在跑,不想加太多设备了。
那软路由开个虚拟ubuntu呗 比树莓派好
GMT+8, 2025-12-16 15:41 , Processed in 1.229240 second(s), 9 queries , MemCached On.
