查看: 8067|回复: 6
[流程系列] 高手帮忙看看,搞晕了
发表于 2020-9-3 20:35:22 | 显示全部楼层 |阅读模式
[{"id":"4a6266e9.7dd058","type":"tab","label":"公共照明开灯","disabled":false,"info":""},{"id":"4b7d25f9.027d9c","type":"server-events","z":"4a6266e9.7dd058","name":"获取无线开关事件","server":"b5a42f15.0fc0c","event_type":"xiaomi_aqara.click","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"waitForRunning":true,"x":170,"y":120,"wires":[["80debcb.400b64"]]},{"id":"80debcb.400b64","type":"switch","z":"4a6266e9.7dd058","name":"筛选出特定的开关","property":"payload.entity_id","propertyType":"msg","rules":[{"t":"eq","v":"binary_sensor.switch_158d0002908722","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":330,"y":220,"wires":[["2decac5a.ad9624"]]},{"id":"2decac5a.ad9624","type":"switch","z":"4a6266e9.7dd058","name":"判断是否单击","property":"payload.event.click_type","propertyType":"msg","rules":[{"t":"eq","v":"single","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":440,"y":320,"wires":[["af2fa9ce.e60938"]]},{"id":"af2fa9ce.e60938","type":"api-current-state","z":"4a6266e9.7dd058","name":"","server":"b5a42f15.0fc0c","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"group.gg_zhaoming","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":480,"y":440,"wires":[[],[]]},{"id":"7943c772.dd30e8","type":"inject","z":"4a6266e9.7dd058","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":520,"wires":[["cc70ef50.19e45"]]},{"id":"cc70ef50.19e45","type":"api-current-state","z":"4a6266e9.7dd058","name":"","server":"b5a42f15.0fc0c","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"group.gg_zhaoming","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":480,"y":520,"wires":[[],[]]},{"id":"b5a42f15.0fc0c","type":"server","z":"","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
为什么同样的节点,上面那个flow,得到的状态是off,下面那个flow得到的状态是on
flow中间要判断一下节点的状态,然后再往下走,这样的写法对吗?
发表于 2020-9-4 11:32:10 | 显示全部楼层
没必要这么写吧  直接 用另一个节点  输出 单  双  长安 不好 ?
 楼主| 发表于 2020-9-4 15:18:25 | 显示全部楼层
能具体一点吗?还是用switch节点吗?新手不太会
发表于 2020-9-4 18:04:54 | 显示全部楼层
用获取状态那个节点,状态那里留空,那么只有一个输出,输出接switch 然后 建立两个输出,一个on一个off
发表于 2020-9-4 18:06:18 | 显示全部楼层
话说,你都混到论坛技术达人,积分那么多应该是老手才对啊
 楼主| 发表于 2020-9-4 18:14:09 | 显示全部楼层
node-red是新手
发表于 2020-9-22 21:14:42 | 显示全部楼层
哈哈哈 老手好
GMT+8, 2025-12-24 17:23 , Processed in 1.359470 second(s), 8 queries , MemCached On.
