查看: 9084|回复: 2
[已解决] HA升级出现 The recorder could not start, please check the log
发表于 2020-8-30 16:05:16 | 显示全部楼层 |阅读模式
如题,不知道那个版本开始的,退回以前也没用,升级也没用。一直提示Recorder
3 分钟前
Invalid config
The following integrations and platforms could not be set up:
recorder
history
logbook
default_config
Please check your config.
 楼主| 发表于 2020-8-30 16:07:17 | 显示全部楼层
日志
Icon mdi:mixcloud was removed from MDI, please replace this icon with an other icon in your config, it will be removed in version 0.115.
下午4:00:31 – components/system_log/__init__.py (WARNING) - 消息首次出现在 下午4:00:26,显示了 2 次
You are using a custom integration for baidu_face which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
下午4:00:26 – loader.py (WARNING) - 消息首次出现在 下午4:00:25,显示了 3 次
Setup failed for recorder: Integration failed to initialize.
下午4:00:26 – setup.py (ERROR) - 消息首次出现在 下午4:00:25,显示了 4 次
Unable to set up dependencies of history. Setup failed for dependencies: recorder
下午4:00:26 – setup.py (ERROR) - 消息首次出现在 下午4:00:25,显示了 3 次
Error during connection setup: (sqlite3.DatabaseError) database disk image is malformed [SQL: UPDATE recorder_runs SET "end"=?, closed_incorrect=? WHERE recorder_runs.run_id = ?] [parameters: (('2020-08-30 07:59:57.649569', 1, 127), ('2020-08-30 07:59:57.649569', 1, 141))] (Background on this error at: http://sqlalche.me/e/13/4xp6) (retrying in 3 seconds)
下午4:00:25 – recorder (ERROR) - 消息首次出现在 下午3:59:57,显示了 10 次
Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: UPDATE recorder_runs SET "end"=?, closed_incorrect=? WHERE recorder_runs.run_id = ?] [parameters: (('2020-08-30 07:59:57.649569', 1, 127), ('2020-08-30 07:59:57.649569', 1, 141))] (Background on this error at: http://sqlalche.me/e/13/4xp6)
Ended unfinished session (id=127 from 2020-08-14 08:35:47.360344)
下午4:00:25 – recorder (WARNING) - 消息首次出现在 下午3:59:57,显示了 20 次
Setup of recorder is taking over 10 seconds.
下午4:00:07 – /usr/local/lib/python3.8/asyncio/events.py (WARNING)
智能家居&单板滑雪痴迷爱好者
发表于 2020-8-30 18:43:51 | 显示全部楼层
sqlite提示数据库文件格式错误,把home-assistant_v2.db文件删掉试试。
如果用的是内存卡之类的闪存器件,估计是要报废了。
参与人数 1金钱 +1 收起 理由
z死囚漫步 + 1 膜拜大神!
GMT+8, 2025-12-23 05:44 , Processed in 0.283346 second(s), 11 queries , MemCached On.
