查看: 5725|回复: 0
[求助] 小米插件运行不起来
发表于 2017-9-5 17:10:15 | 显示全部楼层 |阅读模式
2017-09-05 16:54:35 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-09-05 16:55:36 ERROR (Thread-2) [homeassistant.util.package] Unable to install package netdisco==1.1.0: Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-o0yssiiz/netifaces/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-dz6zvxhm-record/install-record.txt --single-version-externally-managed --prefix  --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-o0yssiiz/netifaces/
2017-09-05 16:55:36 ERROR (MainThread) [homeassistant.setup] Not initializing discovery because could not install dependency netdisco==1.1.0
2017-09-05 16:55:36 ERROR (MainThread) [homeassistant.setup] Setup failed for discovery: Could not install all requirements.
2017-09-05 17:00:32 ERROR (Thread-10) [homeassistant.util.package] Unable to install package https://github.com/Danielhiverse ... aomiGateway==0.3.0: Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-u5ss0l34/pyCrypto/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-7ky4uz1i-record/install-record.txt --single-version-externally-managed --prefix  --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-u5ss0l34/pyCrypto/
2017-09-05 17:00:32 ERROR (MainThread) [homeassistant.setup] Not initializing xiaomi because could not install dependency https://github.com/Danielhiverse ... iaomiGateway==0.3.0
2017-09-05 17:00:32 ERROR (MainThread) [homeassistant.setup] Setup failed for xiaomi: Could not install all requirements.
尝试安装netdisco,但是安装不成功,香橙派
GMT+8, 2025-12-25 16:02 , Processed in 0.392296 second(s), 5 queries , MemCached On.
