查看: 10335|回复: 2
[技术探讨] ESPhome mpu6050 没有数据 求大佬
发表于 2020-8-16 17:48:38 | 显示全部楼层 |阅读模式
i2c:
  sda: 21
  scl: 22
  scan: True
  - platform: mpu6050
    i2c_id: bus16
    address: 0x68
    accel_x:
      name: "MPU6050 Accel X"
    accel_y:
      name: "MPU6050 Accel Y"
    accel_z:
      name: "MPU6050 Accel z"
    gyro_x:
      name: "MPU6050 Gyro X"
    gyro_y:
      name: "MPU6050 Gyro Y"
    gyro_z:
      name: "MPU6050 Gyro z"
    temperature:
      name: "MPU6050 Temperatur
接线都正确 用espeasy 都有数据
发表于 2020-8-18 11:33:52 | 显示全部楼层
MPU6050可能会有0x68和0x69两种地址,你可以看一下esphome开始的log,是不是有iic的搜索结果
 楼主| 发表于 2020-8-18 12:19:15 | 显示全部楼层
tcwj2008 发表于 2020-8-18 11:33
MPU6050可能会有0x68和0x69两种地址,你可以看一下esphome开始的log,是不是有iic的搜索结果 ...
谢谢解答 但是这个地址是对的 另外用espeasy固件测试mpu6050是有数据
log 里显示搜索的是0x68
[07:55:35][I][i2c:033]: Scanning i2c bus for active devices...
[07:55:35][I][i2c:040]: Found i2c device at address 0x68
[07:55:36][C][mpu6050:085]: MPU6050:
[07:55:36][C][mpu6050:086]:   Address: 0x68
[07:55:36][E][mpu6050:088]: Communication with MPU6050 failed!
[07:55:36][C][mpu6050:090]:   Update Interval: 60.0s
GMT+8, 2025-12-30 12:14 , Processed in 0.466073 second(s), 16 queries , MemCached On.
