查看: 12242|回复: 3
[基础教程] hacs 安装时连不上github 怎么办?
发表于 2020-8-14 11:59:39 | 显示全部楼层 |阅读模式
hacs已经 安装成功,在安装插件时连不上github
以下是日志。这个怎么破
Logger: custom_components.hacs.api.repository_data
Source: custom_components/hacs/api/hacs_repository_data.py:114
Integration: HACS ([color=var(--primary-color)]documentation, [color=var(--primary-color)]issues)
First occurred: 上午10:36:15 (3 occurrences)
Last logged: 上午11:35:22
  • Cannot connect to host raw.githubusercontent.com:443 ssl:None [Connect call failed ('::', 443, 0, 0)]
  • Cannot connect to host raw.githubusercontent.com:443 ssl:None [Connect call failed ('0.0.0.0', 443)]
  • Cannot connect to host api.github.com:443 ssl:None [Connect call failed ('13.250.168.23', 443)]
发表于 2020-8-14 14:12:46 | 显示全部楼层
host里配下raw.githubusercontent.com的ip
发表于 2020-8-15 18:07:52 | 显示全部楼层
楼上正解
我也遇到过
发表于 2021-12-3 02:44:42 | 显示全部楼层
请问怎么配置啊
GMT+8, 2026-1-20 03:49 , Processed in 0.061245 second(s), 13 queries , MemCached On.
