查看: 12704|回复: 2
[技术探讨] 请教Aqara P3通过接入HA看不到空调遥控器
发表于 2020-8-14 11:32:10 | 显示全部楼层 |阅读模式
参考https://community.home-assistant ... teway-hub/66933/109将Aqara P3接入了HA,只能看到一个警戒器和一个温度传感器,没有空调遥控。不知道要怎么操作才能看到空调遥控器?
HA版本:0.112.4
参考的步骤:
  • Ensure the Aqara app is in “HomeKit” mode.
  • Press and hold the button the hub until it flashes yellow.
  • Once it’s flashing, add the hub to the Aqara (or Apple Home) app.
  • Open the Aqara app and add all of the sensors that you are going to use.
  • Configure the Hub to behave the way you want (which sensors will trigger the alarm, the volume of the hub, etc).  Note, that in HomeKit mode you cannot change the alarm sound.
  • Once everything is set to your liking, remove the Hub from the Apple HomeKit app.  This will leave the device on your network but will unpair it from HomeKit.
  • Open HomeAssistant and use the “integrations” tab to add a new “HomeKit Controller” integration.  It should automatically find the hub.  Ensure that you enter your Hub’s HK code with the required dashes between the numbers (xxx-xx-xxx).
  • Once pairing is complete you should see everything in Home Assistant and be able to arm the alarm from there.  Note, that you cannot change which sensors will trigger the alarm on the hub unless you unpair from Home Assistant and add to HomeKit again.
发表于 2020-8-18 03:42:30 | 显示全部楼层
同遇到这个问题,已通过修改Home Assistant的代码解决 https://bbs.hassbian.com/forum.p ... p;page=1&extra=
发表于 2022-9-1 14:14:32 | 显示全部楼层
遇到同样的问题,用楼主方法试验下
GMT+8, 2026-1-18 13:51 , Processed in 0.273708 second(s), 11 queries , MemCached On.
