查看: 11113|回复: 1
[求助] 求助!docker pull 时提示/usr空间不足,有什么办法可以解决吗
3 金钱 回复本帖可获得 3 金钱奖励! 每人限 1 次
发表于 2020-7-31 12:32:07 | 显示全部楼层 |阅读模式
root@debian1:~# docker pull homeassistant/home-assistant:0.93.1
0.93.1: Pulling from homeassistant/home-assistant
c5e155d5a1d1: Pull complete
221d80d00ae9: Pull complete
4250b3117dca: Pull complete
3b7ca19181b2: Pull complete
425d7b2a5bcc: Pull complete
dc3049ff3f44: Pull complete
472a6afc6332: Pull complete
5f79c90f8d7c: Pull complete
1051ee813012: Pull complete
d6c1e084f9d4: Pull complete
51db79d8dc3d: Pull complete
60db97bc61a2: Pull complete
8a025e50b7b1: Pull complete
5009a7102f5f: Extracting  291.5MB/291.5MB
b75bdeb487a0: Download complete
failed to register layer: Error processing tar file(exit status 1): write /usr/local/lib/python3.7/site-packages/tensorflow/libtensorflow_framework.so: no space left on device
root@debian1:~# df -h
文件系统                      容量  已用  可用 已用% 挂载点
udev                          729M     0  729M    0% /dev
tmpfs                         150M  9.0M  141M    6% /run
/dev/mapper/debian1--vg-root  7.5G  5.0G  2.2G   71% /
tmpfs                         750M   20M  731M    3% /dev/shm
tmpfs                         5.0M  4.0K  5.0M    1% /run/lock
tmpfs                         750M     0  750M    0% /sys/fs/cgroup
/dev/sda1                     236M   59M  166M   26% /boot
/dev/mapper/debian1--vg-home   27G   97M   26G    1% /home
/dev/mapper/debian1--vg-tmp   547M 1016K  506M    1% /tmp
/dev/mapper/debian1--vg-var   2.8G  407M  2.2G   16% /var
tmpfs                         150M  7.3M  143M    5% /run/user/1000
tmpfs                         150M     0  150M    0% /run/user/0
overlay                       2.8G  407M  2.2G   16% /var/lib/docker/overlay2/76a69d41158cdfacc19a9259ffde3b6e067db72b0b27a84dc8ffc0c36ff11161/merged
root@debian1:~# df -i
文件系统                       Inode 已用(I) 可用(I) 已用(I)% 挂载点
udev                          186586     427  186159       1% /dev
tmpfs                         191818     844  190974       1% /run
/dev/mapper/debian1--vg-root  501952  169686  332266      34% /
tmpfs                         191818      61  191757       1% /dev/shm
tmpfs                         191818       4  191814       1% /run/lock
tmpfs                         191818      17  191801       1% /sys/fs/cgroup
/dev/sda1                      62248     339   61909       1% /boot
/dev/mapper/debian1--vg-home 1782368     466 1781902       1% /home
/dev/mapper/debian1--vg-tmp    36640      45   36595       1% /tmp
/dev/mapper/debian1--vg-var   187312   11356  175956       7% /var
tmpfs                         191818      54  191764       1% /run/user/1000
tmpfs                         191818      12  191806       1% /run/user/0
overlay                       187312   11356  175956       7% /var/lib/docker/overlay2/76a69d41158cdfacc19a9259ffde3b6e067db72b0b27a84dc8ffc0c36ff11161/merged
root@debian1:~# du -sh *
du: 无法访问'*': 没有那个文件或目录
root@debian1:~# du -sh /*
0       /bin
57M     /boot
0       /dev
6.6M    /etc
53M     /home
0       /initrd.img
0       /initrd.img.old
0       /lib
0       /lib32
0       /lib64
0       /libx32
16K     /lost+found
8.0K    /media
4.0K    /mnt
16K     /opt
du: 无法访问'/proc/17016/task/17016/fd/4': 没有那个文件或目录
du: 无法访问'/proc/17016/task/17016/fdinfo/4': 没有那个文件或目录
du: 无法访问'/proc/17016/fd/4': 没有那个文件或目录
du: 无法访问'/proc/17016/fdinfo/4': 没有那个文件或目录
0       /proc
44K     /root
du: 无法访问'/run/user/1000/gvfs': 权限不够
9.0M    /run
0       /sbin
4.0K    /srv
0       /sys
108K    /tmp
05.0G   /usr
474M    /var
0       /vmlinuz
0       /vmlinuz.old
3万
发表于 2020-7-31 13:20:00 | 显示全部楼层
回帖奖励 +3 金钱
前天路由器openwrt升级到 5.4的核心后,按以前的操作一直提示docker使用的空间不足,无法docker pull,找了好久资料终于解决。挂载一个空间大的磁盘 /opt
进入/etc/docker目录,
新建一个daemon.json文件,内容如下:
"data-root": "/opt/", #这个改成你挂载的docker数据分区目录
"log-level": "warn"
最后重启docker或者直接重启路由即可
系统不一样,看看能否参考一下。
GMT+8, 2025-12-23 07:53 , Processed in 0.602686 second(s), 8 queries , MemCached On.
