查看: 16423|回复: 3
Home Assistant 0.112.4无法安装hacs
发表于 2020-7-10 22:24:39 | 显示全部楼层 |阅读模式
下载的 https://github.com/hacs/integration/releases,最新版本1.1.2
解压hacs后,将hacs文件夹放到custom_components下。
重启Home Assistant ,日志打印
2020-07-10 22:13:54 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
到集成去添加hacs ,找不到。 如何解决
发表于 2020-7-12 04:23:38 | 显示全部楼层
仔细阅读readme  你只不过是没添加侧边栏而已
发表于 2021-5-15 05:08:20 来自手机 | 显示全部楼层
请问楼主解决了吗?
 楼主| 发表于 2021-7-11 15:49:37 | 显示全部楼层
多重启几次就可以,或是用无痕模式
GMT+8, 2025-12-29 00:16 , Processed in 0.757614 second(s), 13 queries , MemCached On.
