楼主: aiqienanguatou
求助,hassio中add-on store插件商店无法加载出来,求高手瞅...
 楼主| 发表于 2020-7-11 09:41:37 | 显示全部楼层
XCray 发表于 2020-7-10 19:37
怪不得呢!我还奇怪呢,github虽然访问不太爽,但大部分时候都是没问题的啊。你一说新疆就全理解了,国域 ...
是啊,新疆啥都不行,除了防护级别,这边学软件的都回内地了,难怪留不住人才
发表于 2021-3-18 16:02:58 | 显示全部楼层
我也是哦,商店里已经不能安装新的插件了。。。看来无法好好地和HA玩耍了哦。。。
21-03-18 06:37:20 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-03-18 06:37:20 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-03-18 06:37:20 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-03-18 06:37:20 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-03-18 06:37:20 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-03-18 06:37:20 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-03-18 06:37:20 INFO (MainThread) [supervisor.resolution.fixups.store_execute_remove] Remove invalid Store: core
21-03-18 06:37:20 ERROR (MainThread) [supervisor.store.repository] Can't remove built-in repositories!
21-03-18 06:37:20 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-03-18 06:37:20 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-03-18 06:37:21 WARNING (MainThread) [supervisor.store.git] No valid repository for https://github.com/home-assistant/addons
21-03-18 06:37:21 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
21-03-18 07:37:20 ERROR (MainThread) [supervisor.store.repository] Can't remove built-in repositories!
21-03-18 07:37:20 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-03-18 07:37:20 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-03-18 07:37:22 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-03-18 07:50:42 INFO (MainThread) [supervisor.host.info] Updating local host information
21-03-18 07:50:42 INFO (MainThread) [supervisor.host.services] Updating service information
21-03-18 07:50:42 INFO (MainThread) [supervisor.host.network] Updating local network information
21-03-18 07:50:43 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-03-18 07:50:43 INFO (MainThread) [supervisor.host] Host information reload completed
21-03-18 07:51:35 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
21-03-18 07:51:36 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/home-assistant/addons /data/addons/git/96a017aa
  stderr: 'Cloning into '/data/addons/git/96a017aa'...
fatal: unable to access 'https://github.com/home-assistant/addons/': OpenSSL SSL_connect: Connection reset by peer in connection to github.com:443
21-03-18 07:51:36 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / 96a017aa
21-03-18 07:51:36 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / 96a017aa
21-03-18 07:51:36 ERROR (MainThread) [supervisor.store] Can't load data from repository https://github.com/home-assistant/addons
21-03-18 07:51:36 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
21-03-18 07:51:36 INFO (MainThread) [supervisor.resolution.fixups.store_execute_remove] Remove invalid Store: core
21-03-18 07:51:36 ERROR (MainThread) [supervisor.store.repository] Can't remove built-in repositories!
 楼主| 发表于 2021-3-18 16:45:25 | 显示全部楼层
有其他方法了
seon
发表于 2021-3-18 16:48:02 | 显示全部楼层
aiqienanguatou 发表于 2020-7-10 15:03
谢谢大佬,我桥接的,主机已登上,虚拟机系统也可以登上,都能Google,依旧会出现这个问题,晚会我试下看 ...
docker运行之后,你可以用docker exec登录到容器的bash,在容器里面配置代理,手工运行下git clone就行了,运行完了重启下容器。我遇到这问题是这么搞定的
发表于 2021-3-18 17:02:30 | 显示全部楼层
请指教。感谢
 楼主| 发表于 2021-3-18 17:02:55 | 显示全部楼层
seon 发表于 2021-3-18 16:48
docker运行之后,你可以用docker exec登录到容器的bash,在容器里面配置代理,手工运行下git clone就行了 ...
大佬回复我,受宠若惊,求大佬带带如何抓包,想试下海尔热水器接入ha
seon
发表于 2021-3-18 17:40:44 | 显示全部楼层
抓包好久没搞了,记不太清了,我记得好像是在路由器上刷openwrt固件,然后装openwrt版的wireshark。
设备连入这个WiFi,抓wlan0口的数据分析
 楼主| 发表于 2021-3-19 14:22:24 | 显示全部楼层
设备 ...
不会啊,海尔热水器能接入么
 楼主| 发表于 2021-3-19 14:23:58 | 显示全部楼层
大多是网络问题,我是挂提子解决的
发表于 2021-3-19 14:51:35 | 显示全部楼层
aiqienanguatou 发表于 2021-3-19 14:23
大多是网络问题,我是挂提子解决的
FQ?那就还要在docker里面装软件了哦?
GMT+8, 2026-1-30 23:06 , Processed in 1.811044 second(s), 12 queries , MemCached On.
