查看: 12995|回复: 3
米家空调伴侣2连接homekit遇到问题
发表于 2020-7-3 17:46:11 | 显示全部楼层 |阅读模式
入手了米家空调伴侣2根据LASER-Yi的帖子进行了设置,但是!
[7/3/2020, 5:41:31 PM] [XiaoMiAcPartner] [INFO]Device 192.168.2.242 -> Connecting
[7/3/2020, 5:41:31 PM] [XiaoMiAcPartner] [INFO]Device 192.168.2.242 -> Connected
[7/3/2020, 5:41:36 PM] [XiaoMiAcPartner] [Ac Partner]Sync failed! Error: user ack timeout
    at Object.reject (/usr/local/lib/node_modules/homebridge-mi-acpartner/node_modules/miio/lib/device.js:217:13)
    at Device._onMessage (/usr/local/lib/node_modules/homebridge-mi-acpartner/node_modules/miio/lib/device.js:108:8)
    at Socket.emit (events.js:315:20)
    at UDP.onMessage (dgram.js:910:8) {
  code: -9999
求大神给出解决方案
以下配置信息
    "bridge": {
        "name": "Homebridge 4F2E",
        "username": "0E:7A:EC:87:4F:2E",
        "port": 52258,
        "pin": "031-45-154"
    "platforms": [
            "platform": "XiaoMiAcPartner",
            "devices": {
                "192.168.2.242": "eb3a3c9ca785e386914e15d4e9fd1fb2"
            "accessories": [
                    "name": "Ac Partner",
                    "type": "climate"
    "accessories": []
homebridge版本1.1 运行环境群晖nas+docker
 楼主| 发表于 2020-7-4 13:30:00 来自手机 | 显示全部楼层
自顶一下
发表于 2020-8-26 22:19:16 | 显示全部楼层
顶一下,一样的问题
发表于 2021-5-17 12:12:05 | 显示全部楼层
我也这样,解决了吗?
GMT+8, 2025-12-28 22:18 , Processed in 0.620757 second(s), 11 queries , MemCached On.
