查看: 8723|回复: 2
[流程系列] 控制西门子PLC,有一个问题就是数字怎么转成浮点数还要hex
发表于 2020-7-3 14:39:44 | 显示全部楼层 |阅读模式
最近在控制一个西门子PLC通过nodered,现在想通过改写一个register的数据来控制。
register是单精度浮点数,四个字节。我在界面设置了一个dashboard numbric来设置数字,这个数字输出的是十进制数,我想把它变成四字节的hex的buffer,不知道怎木弄。
下面是一个function可以转value to hex float,但是输出是字符串型的,怎弄弄成纯数字型的?
function InsertString(t, c, n) {
    var r = new Array([]);
    for (var i = 0; i * 2 < t.length; i++) {
        r.push(t.substr(i * 2, n));
    return r.join(c);
function FillString(t, c, n, b) {
    if ((t === "") || (c.length != 1) || (n <= t.length)) {
        return t;
    var l = t.length;
    for (var i = 0; i < n - l; i++) {
        if (b === true) {
            t = c + t;
         else {
            t += c;
    return t;
function SingleToHex(t) {
    if (t === "") {
        return "";
    t = parseFloat(t);
    if (isNaN(t) === true) {
        return "Error";
    if (t === 0) {
        return "00000000";
    var s,
    e,
    m;
    if (t > 0) {
        s = 0;
     else {
        s = 1;
        t = 0 - t;
    m = t.toString(2);
    if (m >= 1) {
        if (m.indexOf(".") == -1) {
            m = m + ".0";
        e = m.indexOf(".") - 1;
     else {
        e = 1 - m.indexOf("1");
    if (e >= 0) {
        m = m.replace(".", "");
     else {
        m = m.substring(m.indexOf("1"));
    if (m.length > 24) {
        m = m.substr(0, 24);
     else {
        m = FillString(m, "0", 24, false)
    m = m.substring(1);
    e = (e + 127).toString(2);
    e = FillString(e, "0", 8, true);
    var r = parseInt(s + e + m, 2).toString(16);
    r = FillString(r, "0", 8, true);
    return InsertString(r, " ", 2).toUpperCase();
发表于 2020-7-9 11:23:22 | 显示全部楼层
用的西门子什么型号的plc啊?
 楼主| 发表于 2020-7-9 22:01:52 | 显示全部楼层
解决了,
    return r.join(c);
        return t;
    var l = t.length;
        if (b === true) {
            t = c + t;
         else {
            t += c;
    return t;
    if (t === "") {
        return "";
    t = parseFloat(t);
        return "Error";
    if (t === 0) {
        return "00000000";
    var s,
    e,
    m;
    if (t > 0) {
        s = 0;
     else {
        s = 1;
        t = 0 - t;
    m = t.toString(2);
    if (m >= 1) {
            m = m + ".0";
     else {
    if (e >= 0) {
     else {
     else {
    m = m.substring(1);
let buf = msg.payload;
let result = SingleToHex(buf);
msg.payload = result;
return msg;
GMT+8, 2025-12-24 17:26 , Processed in 0.732837 second(s), 10 queries , MemCached On.
