楼主: hunterfox
esp8266+继电器 接入 hass
发表于 2020-7-3 21:54:23 | 显示全部楼层
switch:
  - platform: mqtt
    state_topic: "esp/ontest/state"
    command_topic: "esp/GPIO/0"
    payload_on: "1"
    payload_off: "0"
    qos: 0
    retain: true
我最近也在学习hass,这个是今天刚调通的,和你一样esp8266+继电器+MQTT 接入 hass
发表于 2020-7-5 21:09:52 | 显示全部楼层
hejie127 发表于 2020-7-2 22:03
ESPhome  请问该怎么写 开关状态?  实在看不懂这个语言。。
esphome:
  platform: ESP8266
  board: esp01_1m
  esp8266_restore_from_flash: yes
wifi:
  ssid: “你的ssid”
  password: “你的密码”
  ap:
    ssid: "switch"
    password: "00000000"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: "2020"
ota:
  password: "2020"
web_server:
  port: 80
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO2
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      - switch.toggle: relay
switch:
  - platform: gpio
    pin: GPIO0
    inverted: yes
GMT+8, 2025-12-30 14:27 , Processed in 0.050686 second(s), 11 queries , MemCached On.
