查看: 5519|回复: 2
[求助] 刷了ha0.111.4,ha启动好慢,谁帮忙看看
发表于 2020-6-26 10:07:50 | 显示全部楼层 |阅读模式
新刷的ha0.111.4,用论坛的一键脚本刷的
ha启动好慢,谁帮忙看看
启动之后一直显示ha正在启动,某些功能暂不可用
查询日志如下,要怎么解决呢?
2020-06-26 10:55:16 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinish                                                         ed session (id=12 from 2020-06-26 01:49:22.188093)
2020-06-26 10:55:24 WARNING (MainThread) [homeassistant.loader] You are using a custom in                                                         tegration for xiaomi_miio_airconditioningcompanion which has not been tested by Home Assi                                                         stant. This component might cause stability problems, be sure to disable it if you experi                                                         ence issues with Home Assistant.
2020-06-26 11:00:01 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/components/cloud/account_link.py", line 122, in await_tokens
    tokens = await helper.async_get_tokens()
  File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/account_link.py", line 82, in async_get_tokens
    response = await self._get_response()
  File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/account_link.py", line 94, in _get_response
    response = await self._client.receive_json()
  File "/usr/local/lib/python3.7/site-packages/aiohttp/client_ws.py", line 289, in receive_json
    data = await self.receive_str(timeout=timeout)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/client_ws.py", line 275, in receive_str
    msg.data))
TypeError: Received message 257:None is not str
    msg.data))
发表于 2020-6-26 17:55:02 | 显示全部楼层
前几天我也一样的问题。换个快点的卡或U盘。最好用固态硬盘,。
发表于 2020-6-27 13:00:40 | 显示全部楼层
启动慢有可能是插件问题,你启动的时候看一下docker日志,看卡在那里了!
docker logs -f homeassistant
GMT+8, 2025-12-23 07:53 , Processed in 0.601108 second(s), 7 queries , MemCached On.
