查看: 4875|回复: 4
小白请教个问题,安装时错误提示
发表于 2020-6-12 13:24:10 | 显示全部楼层 |阅读模式
Installing collected packages: ciso8601, homeassistant
    Running setup.py install for ciso8601 ... error
    ERROR: Command errored out with exit status 1:
     command: 'c:\users\administrator\appdata\local\programs\python\python38\pyt
hon.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\
Administrator\\AppData\\Local\\Temp\\pip-install-2f28_muq\\ciso8601\\setup.py'"'
"'; __file__='"'"'C:\\Users\\Administrator\\AppData\\Local\\Temp\\pip-install-2f
28_muq\\ciso8601\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file
__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(c
ode, __file__, '"'"'exec'"'"'))' install --record 'C:\Users\Administrator\AppDat
a\Local\Temp\pip-record-i68gzdj8\install-record.txt' --single-version-externally
-managed --compile --install-headers 'c:\users\administrator\appdata\local\progr
ams\python\python38\Include\ciso8601'
         cwd: C:\Users\Administrator\AppData\Local\Temp\pip-install-2f28_muq\cis
o8601\
    Complete output (12 lines):
    running install
    running build
    running build_py
    package init file 'ciso8601\__init__.py' not found (or not a regular file)
    creating build
    creating build\lib.win-amd64-3.8
    creating build\lib.win-amd64-3.8\ciso8601
    copying ciso8601\__init__.pyi -> build\lib.win-amd64-3.8\ciso8601
    copying ciso8601\py.typed -> build\lib.win-amd64-3.8\ciso8601
    running build_ext
    building 'ciso8601' extension
    error: Microsoft Visual C++ 14.0 is required. Get it with "Microsoft Visual
C++ Build Tools": https://visualstudio.microsoft.com/downloads/
ERROR: Command errored out with exit status 1: 'c:\users\administrator\appdata\l
ocal\programs\python\python38\python.exe' -u -c 'import sys, setuptools, tokeniz
e; sys.argv[0] = '"'"'C:\\Users\\Administrator\\AppData\\Local\\Temp\\pip-instal
l-2f28_muq\\ciso8601\\setup.py'"'"'; __file__='"'"'C:\\Users\\Administrator\\App
Data\\Local\\Temp\\pip-install-2f28_muq\\ciso8601\\setup.py'"'"';f=getattr(token
ize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'
\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --reco
rd 'C:\Users\Administrator\AppData\Local\Temp\pip-record-i68gzdj8\install-record
.txt' --single-version-externally-managed --compile --install-headers 'c:\users\
administrator\appdata\local\programs\python\python38\Include\ciso8601' Check the
logs for full command output.
智能家居&单板滑雪痴迷爱好者
发表于 2020-7-27 09:54:29 | 显示全部楼层
这个论坛对小白来说确实太冷漠了。。。
不过确实有人对试图帮助自己的人毫无感激不说,甚至还恶语相向,恐怕也是造成很多大神不愿意回答初级问题的一个重要原因。
小白的问题往往比较低级,大神们回答的时候难免会不耐烦,小白的自尊心就会感觉受到了伤害。。。
不扯了,简单回答以下几点:
1、Windows是最不推荐的ha安装环境,小白更不推荐,坑特别多。推荐在windows里安装虚拟机软件、在虚拟机里跑hassio(按最新的叫法,应为hassos),最省心,也最好用。
2、你贴出来的错误提示已经很清楚了:缺少微软 Visual C++ 14.0的编译环境,到微软官网下载安装。不过我还是推荐第一点。
spit
发表于 2021-6-21 12:40:47 | 显示全部楼层
大神 我也遇到同样的问题 已经把VC++装上了,还是同样的提示,该如何是好?谢谢
智能家居&单板滑雪痴迷爱好者
发表于 2021-6-21 17:33:58 | 显示全部楼层
spit 发表于 2021-6-21 12:40
大神 我也遇到同样的问题 已经把VC++装上了,还是同样的提示,该如何是好?谢谢 ...
1、Windows是最不推荐的ha安装环境,小白更不推荐,坑特别多。推荐在windows里安装虚拟机软件、在虚拟机里跑hassos,最省心,也最好用。
2、我从来没在windows底下尝试过安装ha,所以也不知道会有什么问题以及如何解决,我只是就楼主发的错误信息说事儿。
3、如果不喜欢hassos,虚拟机跑个debian之类的linux系统,跑docker或者直接在python虚拟环境里跑core都可以,愿意折腾跑hassio也行
发表于 2022-4-21 13:49:28 | 显示全部楼层
我也不懂怎样在windows里安装...
GMT+8, 2026-2-6 16:13 , Processed in 0.065667 second(s), 19 queries , MemCached On.
