查看: 9022|回复: 4
[流程系列] 不懂就问,求大神普及,怎么通过rode发送hex,到设备呢?
发表于 2020-6-11 12:45:13 | 显示全部楼层 |阅读模式
事情是这样子的,家里有个智能插座,也抓包到16进制的包,用调试工具测试也能控制,想写进hass里,钻研多天无果,上论坛里求助大神解答。上图帮助分析下:
这个是抓到的包
用这个测试,无果。
怎么发送才是正确的呢?求大神接打
发表于 2020-6-11 15:47:31 | 显示全部楼层
没玩过,二进制流看看?
发表于 2020-6-11 16:36:32 | 显示全部楼层
用inject触发function,function里写数据,msg.payload = hex,js语言呗,你自己研究下怎么转吧,我也不会
http://blog.chinaunix.net/uid-14735472-id-3191427.html
 楼主| 发表于 2020-6-11 19:24:06 来自手机 | 显示全部楼层
情非殇 发表于 2020-6-11 16:36
用inject触发function,function里写数据,msg.payload = hex,js语言呗,你自己研究下怎么转吧,我也不会: ...
应该不用转换吧,机器只识别这个16进制,怎么把这个16进制包,用udp发送出去就可以了。我也是小白一个
发表于 2020-6-11 21:52:02 | 显示全部楼层
shangjiazi 发表于 2020-6-11 19:24
应该不用转换吧,机器只识别这个16进制,怎么把这个16进制包,用udp发送出去就可以了。我也是小白一个 ...
找了一个以前自己写过的测试,你可以试一下,栝号里的数据是我自己的,你自己搞你的
[{"id":"b91f81cb.f77a9","type":"inject","z":"82748e98.877e3","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":330,"y":1960,"wires":[["591e983a.1e10e8"]]},{"id":"d4a3b5f9.a0ce38","type":"debug","z":"82748e98.877e3","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":850,"y":1960,"wires":[]},{"id":"591e983a.1e10e8","type":"function","z":"82748e98.877e3","name":"继电器1关","func":"msg.payload = new Buffer([0x01,0x05,0x00,0x01,0x00,0x01,0x5D,0xCA])\nreturn msg;","outputs":1,"noerr":0,"x":490,"y":1960,"wires":[["d4a3b5f9.a0ce38"]]}]
return msg;
GMT+8, 2025-12-17 00:28 , Processed in 0.412653 second(s), 9 queries , MemCached On.
