查看: 9834|回复: 0
[求助] 安装yaml编辑器遇到难题,不能运行.py文件
发表于 2020-6-10 22:20:35 | 显示全部楼层 |阅读模式
用的群晖
提示如下
root @ DS918Plus:/hass.io/homeassistant# ./configurator.py -ash:./configurator.py:/
usr / bin / python3:错误的解释器:无此类文件或目录
我使用的putty,请问是群晖上却什么软件还是命令不对?安装
别的命令是也是不行下边是安装和风天气出的提示
root@DS918Plus:/hass.io/homeassistant/custom_components/he_weather# curl -O https://raw.githubusercontent.com/morestart/HeWeather/More-than-0.63/manifest.json
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: https://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using a "bundle"
of Certificate Authority (CA) public keys (CA certs). If the default
bundle file isn't adequate, you can specify an alternate file
using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
the bundle, the certificate verification probably failed due to a
problem with the certificate (it might be expired, or the name might
not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use
the -k (or --insecure) option.
HTTPS-proxy has similar options --proxy-cacert and --proxy-insecure.
证书我今天刚申请的阿里云的也安装好了 设置的默认了
请问各位到底哪里的原因啊,谢谢了
GMT+8, 2025-12-15 23:59 , Processed in 0.642464 second(s), 8 queries , MemCached On.
