查看: 7977|回复: 6
[求助] esp8266刷esphome后wifi无法连接
发表于 2020-6-9 16:03:32 | 显示全部楼层 |阅读模式
按照官方教程刷固件后,wifi无法连接,修改手动ip也不行,求指教
INFO Reading configuration /config/esp8266.yaml...INFO Generating C++ source...INFO Compiling app...INFO Running:  platformio run -d /config/esp8266Processing esp8266 (board: esp01_1m; framework: arduino; platform: [email protected])--------------------------------------------------------------------------------HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB FlashPACKAGES:  - framework-arduinoespressif8266 2.20502.0 (2.5.2)  - tool-esptool 1.413.0 (4.13)  - tool-esptoolpy 1.20600.0 (2.6.0)  - toolchain-xtensa 1.40802.0 (4.8.2)Dependency Graph|-- <ESPAsyncTCP-esphome> 1.2.2|   |-- <ESP8266WiFi> 1.0|-- <ESP8266WiFi> 1.0|-- <ESP8266mDNS> 1.2|   |-- <ESP8266WiFi> 1.0|-- <ESPAsyncWebServer-esphome> 1.2.6|   |-- <ESPAsyncTCP-esphome> 1.2.2|   |   |-- <ESP8266WiFi> 1.0|   |-- <Hash> 1.0|   |-- <ESP8266WiFi> 1.0|-- <DNSServer> 1.1.1|   |-- <ESP8266WiFi> 1.0Compiling .pioenvs/esp8266/src/main.cpp.oLinking .pioenvs/esp8266/firmware.elfBuilding .pioenvs/esp8266/firmware.binRetrieving maximum program size .pioenvs/esp8266/firmware.elfChecking size .pioenvs/esp8266/firmware.elfAdvanced Memory Usage is available via "PlatformIO Home > Project Inspect"RAM:   [====      ]  43.9% (used 35932 bytes from 81920 bytes)Flash: [====      ]  38.5% (used 393768 bytes from 1023984 bytes)Creating BIN file ".pioenvs/esp8266/firmware.bin" using ".pioenvs/esp8266/firmware.elf"========================= [SUCCESS] Took 17.17 seconds =========================INFO Successfully compiled program.INFO Resolving IP address of esp8266.localERROR Error resolving IP address of esp8266.local. Is it connected to WiFi?ERROR (If this error persists, please set a static IP address: https://esphome.io/components/wifi.html#manual-ips)ERROR Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -2] Name or service not known
发表于 2020-6-9 20:01:51 | 显示全部楼层
esphome的wifi对无线有要求,我遇到过用刷esphome无法连接,但刷easyesp能连接的wifi信号。你可以换个普通wifi路由器试一下,做一个排除。
发表于 2020-6-10 08:21:17 | 显示全部楼层
xuyang 发表于 2020-6-9 20:01
esphome的wifi对无线有要求,我遇到过用刷esphome无法连接,但刷easyesp能连接的wifi信号。你可以换个普通w ...
如果有这可能的话,手机开个热点暂时冒充下测试,最简单,会不会是5G和2.4G的混合路由背锅?
 楼主| 发表于 2020-6-10 09:17:13 | 显示全部楼层
情非殇 发表于 2020-6-10 08:21
如果有这可能的话,手机开个热点暂时冒充下测试,最简单,会不会是5G和2.4G的混合路由背锅? ...
我用的是unifi ap,,2.4和5g混用,,但是我把5g暂时关闭测试也不行,
发表于 2020-6-11 15:27:26 | 显示全部楼层
1. 先透過傳輸線更新韌體與監看 Log,就可以先判斷 wifi 連線有沒有成功, 是否有從 DHCP 取到 IP
2. 在區網內的每個裝置的 name 不能有重複,有重複時 name.local 就會有問題
3. ESP01 記憶體太小,無法透過網路 OTA 更新
发表于 2020-12-27 00:22:56 来自手机 | 显示全部楼层
同样的问题
发表于 2020-12-27 14:24:53 来自手机 | 显示全部楼层
信道和加密方式问题,测试更换信道。(换设备/重启路由就可以)
GMT+8, 2025-12-23 01:18 , Processed in 1.361017 second(s), 12 queries , MemCached On.
