查看: 9682|回复: 1
[已解决] Hassio莫名其妙出现了几条error
发表于 2020-6-4 21:01:31 | 显示全部楼层 |阅读模式
这些error出现了很久了不知道安装了哪些组件导致的,请教各位大神不胜感激
以下是log信息
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host api.github.com:443 ssl:None [Connect call failed ('13.250.168.23', 443)]
2020-06-04 15:06:43 ERROR (MainThread) [backoff] Giving up call_api(...) after 5 tries (aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host api.github.com:443 ssl:None [Connect call failed ('13.250.168.23', 443)])
2020-06-04 17:05:31 ERROR (MainThread) [backoff] Giving up call_api(...) after 5 tries (aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host api.github.com:443 ssl:None [Connect call failed ('13.250.168.23', 443)])
2020-06-04 17:05:31 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
确实HACS的问题,连接好的时候不报错。可是有没有办法不让它报错呢?
发表于 2020-6-4 23:47:14 | 显示全部楼层
hacs 出问题了吧,连不上 github
GMT+8, 2025-12-16 07:05 , Processed in 0.156282 second(s), 11 queries , MemCached On.
