楼主: ufonba
[经验分享] 抓狂了,0.110的xiaomi_miio冲突
 楼主| 发表于 2020-5-25 01:39:22 | 显示全部楼层
miniknife 发表于 2020-5-22 23:57
应该是由于使用了自定义的miio插件导致的,把 manifest.json 文件里改成 python-miio>=0.5.0.1 ...
谢谢,果然是自定义的空调伴侣插件问题,syssi/xiaomi_airconditioningcompanion删了之后就正常了,我试下修改下,看能不能用
 楼主| 发表于 2020-5-25 14:53:44 | 显示全部楼层
不是hassio的问题,是syssi/xiaomi_airconditioningcompanion没有跟着更新miio的版本
参与人数 1金钱 +5 收起 理由
neoyang + 5
发表于 2020-6-3 16:21:58 | 显示全部楼层
ufonba 发表于 2020-5-25 01:39
谢谢,果然是自定义的空调伴侣插件问题,syssi/xiaomi_airconditioningcompanion删了之后就正常了,我试 ...
我删除了空调伴侣插件以后错误依然是一样的
 楼主| 发表于 2020-6-4 11:56:17 | 显示全部楼层
你可能还有其它插件,然后你就把日志贴出来大家看看是不是同一个问题
发表于 2020-6-11 23:56:38 | 显示全部楼层
我是万能遥控器和插座不能用,删了空调插件也不行
Logger: homeassistant.config
Source: components/xiaomi_miio/gateway.py:4
First occurred: 下午11:51:04 (2 occurrences)
Last logged: 下午11:51:05
Platform error: switch
Platform error: remote
  File "/usr/src/homeassistant/homeassistant/config.py", line 777, in async_process_component_config
    platform = p_integration.get_platform(domain)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 273, in get_platform
    f"{self.pkg_path}.{platform_name}"
  File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
  File "<frozen importlib._bootstrap>", line 983, in _find_and_load
  File "<frozen importlib._bootstrap>", line 953, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 728, in exec_module
  File "/usr/src/homeassistant/homeassistant/components/xiaomi_miio/__init__.py", line 8, in <module>
    from .config_flow import CONF_FLOW_TYPE, CONF_GATEWAY
  File "/usr/src/homeassistant/homeassistant/components/xiaomi_miio/config_flow.py", line 12, in <module>
    from .gateway import ConnectXiaomiGateway
  File "/usr/src/homeassistant/homeassistant/components/xiaomi_miio/gateway.py", line 4, in <module>
    from miio import DeviceException, gateway
ImportError: cannot import name 'gateway' from 'miio' (/config/deps/lib/python3.7/site-packages/miio/__init__.py)
我的解决了,在尝试手动把\deps\lib\python3.7\site-packages\miio手动更新也失败之后,我直接把这个文件夹删掉了,本来想让HA自动修复一下的,结果重启之后一切都恢复了,意外之喜
发表于 2020-6-22 22:30:14 | 显示全部楼层
所以这有解决办法了吗?
发表于 2021-1-11 23:13:30 | 显示全部楼层
貌似这个方法还挺管用的。
刚开始删掉miio整个目录后重启,不太好使;
后来只删除miio目录下的 __pycache__目录,重启后就好了。
发表于 2021-1-23 11:46:13 | 显示全部楼层
guibaodear 发表于 2021-1-11 23:13
貌似这个方法还挺管用的。
后来只删除miio目录下的 __pycache ...
我是hassos安装的。要怎么才能删除这个文件?
发表于 2021-1-26 17:37:17 | 显示全部楼层
我按这个方法,测试后,不报错了,但是找不到实体,
发表于 2021-2-22 15:07:28 | 显示全部楼层
这个具体不太清楚,我是在群晖里用docker安装的ha。
前几天重启ha后又出现这个问题了,导致小米插座和PM2.5检测仪无法使用。
老办法,进入HA的docker,再进入目录 /usr/local/lib/python3.8/site-packages/miio,
删掉里面的 __pycache__  ,重启后就好了。
GMT+8, 2025-12-29 10:25 , Processed in 0.943430 second(s), 12 queries , MemCached On.
