楼主: lidicn
[插件集成] 彩云SE【修复BUG】【温度曲线图】【天气预警】【异地天气】
发表于 2018-4-3 00:42:38 | 显示全部楼层
感谢提供建议。
发表于 2018-4-4 00:11:35 | 显示全部楼层
嘻嘻,正需要
发表于 2018-4-4 11:23:03 | 显示全部楼层
遇到这样的错误,请问是哪里出错了?谢谢!
Home Assistant
0.66.1
Path to configuration.yaml: /home/homeassistant/.homeassistant
Developed by a bunch of awesome people.
Published under the Apache 2.0 license
Source: server — frontend-ui
Built using Python 3, Polymer 2.6.0, Icons by Google and MaterialDesignIcons.com.
Frontend JavaScript version: latest
Error while setting up platform CaiyunweatherSE
11:20 AM custom_components/sensor/CaiyunweatherSE.py (ERROR)
Press the button to load the full Home Assistant log.
Log Details (ERROR)
Wed Apr 04 2018 11:20:25 GMT+0800 (中国标准时间)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 82, in async_setup
    SLOW_SETUP_MAX_WAIT, loop=hass.loop)
  File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
    return fut.result()
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/home/homeassistant/.homeassistant/custom_components/sensor/CaiyunweatherSE.py", line 357, in setup_platform
    dev0.append(CaiyunSensor(CONF_MINUTELY, 'tracker', entity_id[i]+'_description', None, 'mdi:heart-half-full', api_key, entity_id[i], hass, download_file, download_path, alert))
  File "/home/homeassistant/.homeassistant/custom_components/sensor/CaiyunweatherSE.py", line 435, in __init__
    elatitude = self.tracker_state.attributes.get('latitude')
AttributeError: 'NoneType' object has no attribute 'attributes'
发表于 2018-4-5 13:44:59 | 显示全部楼层
谢谢分享
发表于 2018-4-10 12:59:04 | 显示全部楼层
跟风占楼,有想法再来更新
发表于 2018-4-20 15:21:22 | 显示全部楼层
不错不错。谢谢了
发表于 2018-4-29 14:50:37 | 显示全部楼层
就选你这个NNN
发表于 2018-4-29 21:46:08 | 显示全部楼层
异地天气只有这个东西,里面的 单项怎么才能 提出来呢 ?
发表于 2018-4-29 23:02:44 来自手机 | 显示全部楼层
看起来好复杂的配置
发表于 2018-4-30 13:53:49 来自手机 | 显示全部楼层
这个正好要学习
GMT+8, 2025-11-23 06:04 , Processed in 0.467461 second(s), 12 queries , MemCached On.
