楼主: lidicn
[插件集成] 彩云SE【修复BUG】【温度曲线图】【天气预警】【异地天气】
发表于 2017-11-18 19:47:57 | 显示全部楼层
谢谢分享
发表于 2017-11-18 22:06:37 | 显示全部楼层
谢谢分享
发表于 2017-11-19 00:41:11 | 显示全部楼层
新手学习
发表于 2017-11-19 21:50:46 | 显示全部楼层
不错不错!!
发表于 2017-11-20 10:59:41 | 显示全部楼层
厉害了,学习~~~~~·
发表于 2017-11-21 22:01:48 | 显示全部楼层
学习一下
发表于 2017-11-22 15:33:03 | 显示全部楼层
试验一下
发表于 2017-11-23 13:35:24 | 显示全部楼层
提示好多错误,
Path to configuration.yaml: /config
[color=var(--dark-primary-color)]Developed by a bunch of awesome people.
Published under the Apache 2.0 license
Source: [color=var(--dark-primary-color)]server
— [color=var(--dark-primary-color)]frontend-ui
Built using [color=var(--dark-primary-color)]Python 3, [color=var(--dark-primary-color)]Polymer 2.0.1, Icons by [color=var(--dark-primary-color)]Google and [color=var(--dark-primary-color)]MaterialDesignIcons.com.
The following errors have been logged this session:2017-11-23 05:55:30 WARNING (SyncWorker_36) [custom_components.sensor.CaiyunweatherSE] File or data not present at the moment: realtime.json2017-11-23 05:55:30 WARNING (SyncWorker_18) [custom_components.sensor.CaiyunweatherSE] File or data not present at the moment: realtime.json2017-11-23 05:55:30 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform CaiyunweatherSETraceback (most recent call last):  File "/config/custom_components/sensor/CaiyunweatherSE.py", line 1190, in update    with open(self._forecastjson_path, 'r', encoding='utf-8') as file_data:FileNotFoundError: [Errno 2] No such file or directory: '/config/downloads/forecast.json'During handling of the above exception, another exception occurred:Traceback (most recent call last):  File "/usr/src/app/homeassistant/helpers/entity_component.py", line 170, in _async_setup_platform    SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
发表于 2017-11-23 17:26:42 | 显示全部楼层
看看更新
发表于 2017-11-23 17:49:38 | 显示全部楼层
感谢楼主分享
GMT+8, 2026-1-11 16:21 , Processed in 1.646196 second(s), 11 queries , MemCached On.
