查看: 9137|回复: 6
[流程系列] nodered新手上路,第一道门就被困了几天,哈哈
发表于 2020-5-17 23:34:31 | 显示全部楼层 |阅读模式
跟论坛里的大神学习,尝试用HTTP IN搞一个浏览器的触发动作,可是HTTP IN的url死活无响应,但是NR可以正常访问
HA版本:0.105.3
NR版本:6.1.4
NR端口:1880
NR配置如下图:
http://192.168.2.105:1880访问,输入HA的账号密码,可以进入NR
然后建了一个http in的流图如下:
TEST配置如下:
然后用http://192.168.2.105:1880/test触发这个HTTP IN,一直提示无法get
不知是哪里有问题,求大神给点指导
 楼主| 发表于 2020-5-21 15:31:02 | 显示全部楼层
有没大侠给指导一下,十分感谢!!
发表于 2020-6-23 18:23:01 | 显示全部楼层
直接说你想要做什么,大神们更感兴趣,能给你提供解决方案,你这样问,真的是搞不明白你想做啥
发表于 2020-7-30 16:15:35 | 显示全部楼层
这是进入指定网址就触发的吗? 你实现了吗?
发表于 2020-9-3 10:30:44 | 显示全部楼层
同求,httpnode认证问题
发表于 2020-9-3 19:25:14 | 显示全部楼层
應該是後面兩個錯了
[{"id":"3bb75fcd.b91fb","type":"http in","z":"9595d93b.821a58","name":"/test","url":"/test","method":"get","upload":false,"swaggerDoc":"","x":940,"y":330,"wires":[["16d983e6.b33a3c"]]},{"id":"16d983e6.b33a3c","type":"template","z":"9595d93b.821a58","name":"Hello HomeAssistant","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<html>\n    <body>\n        <h1>Hello HomeAssistant</h1>\n    </body>\n</html>","x":1120,"y":330,"wires":[["55e1c09c.b65a9"]]},{"id":"55e1c09c.b65a9","type":"http response","z":"9595d93b.821a58","name":"","statusCode":"","headers":{},"x":1310,"y":330,"wires":[]}]
 楼主| 发表于 2020-9-3 22:28:56 | 显示全部楼层
erj002 发表于 2020-9-3 10:30
同求,httpnode认证问题
登录的url错了,要带endpoint,这里有一个小坑
http://192.168.2.105:1880/endpoint/test
GMT+8, 2025-12-24 17:25 , Processed in 0.953257 second(s), 13 queries , MemCached On.
