查看: 11138|回复: 11
[基础教程] homeassistant
发表于 2019-6-23 12:22:44 | 显示全部楼层 |阅读模式
还是另外有其他写法    为什么我写的tmall_genie: true没用。。。在配置里面没有
- -求大佬教学
 楼主| 发表于 2019-6-25 11:19:31 | 显示全部楼层
1096503000 发表于 2019-6-24 07:59
homeassistant:
  # Name of the location where Home Assistant is running
老哥万分感谢- -  我这边学会了
流水无味
灌水之王
发表于 2019-6-24 11:50:10 | 显示全部楼层
你俩直接改文本 小心windows下的回车
发表于 2019-6-24 07:59:22 | 显示全部楼层
易大宝 发表于 2019-6-23 23:53
homeassistant:
homeassistant:
  # Location required to calculate the time the sun rises and sets
  latitude: 28.2277415897
  longitude: 112.8766929807
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: Asia/Shanghai
  # Customization file
  customize:
    switch.米家智能插座增强版: #你的插座ID,英文的,homeassistant里面去看
      tmall_genie: true
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Sensors
  # Weather prediction
  - platform: yr
switch:
  - platform: xiaomi_miio
    friendly_name: 米家智能插座增强版
    host: 192.168.123.161
    token: 976c75563aa756794f473f5
    friendly_name: 米家智能插线板
    host: 192.168.123.162
    token: 71ec2b4e2e527be3980d9b
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
automation: !include automations.yaml
script: !include scripts.yaml
 楼主| 发表于 2019-6-23 23:53:22 | 显示全部楼层
1096503000 发表于 2019-6-23 22:10
你直接复制配置回复,不要发成图片,我改个样式给你看
homeassistant:
  elevation: 0
  unit_system: metric
  customize: !include customize.yaml
default_config:
# http:
# Sensors
  - platform: yr
switch:
    tmall_genie: true
    tmall_genie: true
# Text to speech
tts:
发表于 2019-6-23 22:10:28 | 显示全部楼层
易大宝 发表于 2019-6-23 16:49
老哥我在customize.yaml写不对
在configuration.yaml写吧  customize: !include customize.yaml
发表于 2019-6-23 21:30:28 | 显示全部楼层
不是改你配置,只是给你的已经配置好的设备实体上,附加别的参数,比如friendly_name,,,啥的,
比如你的需求tmall_genie: true这个参数,你只要正常接入ha之后,找到设备id,然后从customize下面配置附加参数就好了,,
上面给你的例子已经很清楚了,你抄一下就好了,把switch.s7改成你要添加参数的设备id就OK了
 楼主| 发表于 2019-6-23 16:49:45 | 显示全部楼层
1096503000 发表于 2019-6-23 13:51
homeassistant:
  customize:
    switch.s7:
改成图片这也也不对。。。恕小弟真心没看懂- -
发表于 2019-6-23 13:51:47 | 显示全部楼层
易大宝 发表于 2019-6-23 13:05
老铁能给一个截图吗,看一下你是怎么写的
homeassistant:
  customize:
    switch.s7:
      friendly_name: 卧室灯
      icon: mdi:lightbulb
      tmall_genie: true
 楼主| 发表于 2019-6-23 13:05:26 来自手机 | 显示全部楼层
1096503000 发表于 2019-6-23 12:43
写在customize下
老铁能给一个截图吗,看一下你是怎么写的
GMT+8, 2025-9-9 05:49 , Processed in 0.076269 second(s), 15 queries , MemCached On.
