『瀚思彼岸』» 智能家居技术论坛
查看: 5618|回复: 10
[流程系列] 周末调休上班提醒
帖子
840
发表于 2019-5-7 10:12:25 | 显示全部楼层 |阅读模式
五一假期后的第一个周日有没有小伙伴因为闹钟没响迟到的?
这个流会在关键的时候提醒你上班
[{"id":"e446acb9.cbda4","type":"inject","z":"4c7e7d2d.2c59d4","name":"周末上班时间","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"30 08 * * 6,0","once":false,"onceDelay":0.1,"x":120,"y":1000,"wires":[["bb317a38.4652a8"]]},{"id":"bb317a38.4652a8","type":"http request","z":"4c7e7d2d.2c59d4","name":"节假日","method":"GET","ret":"txt","paytoqs":false,"url":"http://timor.tech/api/holiday/info","tls":"","proxy":"","authType":"basic","x":270,"y":1000,"wires":[["d1f1411d.3b7ed"]]},{"id":"d1f1411d.3b7ed","type":"function","z":"4c7e7d2d.2c59d4","name":"是否上班","func":"var holidayData = JSON.parse(msg.payload);\nvar work = 0;\nif(holidayData.holiday && holidayData.holiday.wage == 1){\n    work = 1;\n}\nmsg.payload = work;\nreturn msg;","outputs":1,"noerr":0,"x":400,"y":1000,"wires":[["62e38010.e4394"]]},{"id":"62e38010.e4394","type":"switch","z":"4c7e7d2d.2c59d4","name":"上班","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":530,"y":1000,"wires":[["24bec347.aa465c"]]},{"id":"24bec347.aa465c","type":"api-call-service","z":"4c7e7d2d.2c59d4","name":"音量调大","server":"42856857.1cb6d8","service_domain":"hello_miai","service":"set_vol","data":"{"vol":80}","mergecontext":"","output_location":"","output_location_type":"none","x":660,"y":1000,"wires":[["6df6b763.411c48"]]},{"id":"6df6b763.411c48","type":"api-call-service","z":"4c7e7d2d.2c59d4","name":"叫醒我","server":"42856857.1cb6d8","service_domain":"hello_miai","service":"force_send","data":"{"message":"快醒醒, 今天上班, 别睡懒觉拉"}","mergecontext":"","output_location":"","output_location_type":"none","x":790,"y":1000,"wires":[[]]},{"id":"42856857.1cb6d8","type":"server","z":"","name":"Home Assistant","legacy":false,"hassio":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":false}]
这个网站的代码好像有时会丢字符,如果导入失败可以用这个gist里的代码试试https://gist.github.com/xuqiu/eb7fedd1311697785c9a4e787e50dc40
帖子
6349
Rank: 8Rank: 8
发表于 2019-5-7 10:20:15 | 显示全部楼层
学习一下
帖子
2014
Rank: 6Rank: 6
发表于 2019-5-7 10:54:03 | 显示全部楼层
api稳定吗
帖子
8580
Rank: 8Rank: 8
发表于 2019-5-7 15:16:03 | 显示全部楼层
nodered流我要顶一下学习
帖子
5340
Rank: 8Rank: 8
发表于 2019-5-7 18:43:23 | 显示全部楼层
这个可以有!
帖子
Rank: 9Rank: 9Rank: 9
发表于 2019-5-7 21:41:26 | 显示全部楼层
这个是刚需
帖子
2495
Rank: 6Rank: 6
发表于 2019-5-7 22:29:34 | 显示全部楼层
碰上个周末也不容易
帖子
840
 楼主| 发表于 2019-5-8 10:23:52 | 显示全部楼层
用了几个月,感觉不错. 详细见 http://timor.tech/api/holiday
帖子
358
Rank: 3Rank: 3
发表于 2023-4-1 22:25:15 | 显示全部楼层
谢谢!!!!!!!!!!!!!
帖子
1774
Rank: 6Rank: 6
发表于 2023-6-8 09:08:17 | 显示全部楼层
大佬帮忙看一下,这是什么情况
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-5-21 01:52 , Processed in 0.089693 second(s), 35 queries .
Powered by Discuz! X3.4
