『瀚思彼岸』» 智能家居技术论坛
查看: 15493|回复: 15
[流程系列] 【v1.0.3】让Node-RED直接支持搜索和控制内网控客设备
帖子
2046
Rank: 8Rank: 8
突出贡献
发表于 2019-3-27 12:45:20 | 显示全部楼层 |阅读模式
本节点支持不通过HA来中转控制控客设备,并且配合dashboard能支持很好的可视化和联动
1.0.3修订
1、支持对于相同动作不重复操作
2、支持免填写密码和mac地址
控客的nodered节点
提供发现操作两个节点
发现节点用于发现内网可操作的控客开关,获取相关信息用于操作节点操作用
操作节点用于直接操作配置好的控客开关,同时也提供去检查指定开关状态的功能
基于以上两个功能可完成局域网控客开关的操作
安装
# 去nodered目录
npm i node-red-contrib-konkeio
nodered 范例流
请直接导入使用
        "id": "211b19ee.7070b6",
        "type": "konkeio-discover",
        "z": "4cc2a712.3a16e8",
        "timeout": 1000,
        "x": 670,
        "y": 180,
        "wires": [
                "ad5e51c5.80441"
        "id": "6ed3bee1.0d6b4",
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 505,
        "y": 180,
        "wires": [
                "211b19ee.7070b6"
        "id": "ad5e51c5.80441",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "x": 830,
        "y": 180,
        "wires": []
        "id": "1fa33e97.04d741",
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "",
        "repeat": "2",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 520,
        "y": 240,
        "wires": [
                "f9ef7874.cbfdf8"
        "id": "f9ef7874.cbfdf8",
        "type": "konkeio-action",
        "name": "检测",
        "ip": "192.168.200.236",
        "sw": "check",
        "x": 670,
        "y": 240,
        "wires": [
                "7249e928.996fe8"
        "id": "7249e928.996fe8",
        "type": "ui_switch",
        "name": "",
        "label": "插座",
        "tooltip": "",
        "group": "72a893e.0d55c6c",
        "order": 4,
        "width": 0,
        "height": 0,
        "passthru": true,
        "decouple": "false",
        "topic": "",
        "style": "",
        "onvalue": "true",
        "onvalueType": "bool",
        "onicon": "",
        "oncolor": "",
        "offvalue": "false",
        "offvalueType": "bool",
        "officon": "",
        "offcolor": "",
        "x": 825,
        "y": 240,
        "wires": [
                "6bcbe79f.53fe38"
        "id": "6bcbe79f.53fe38",
        "name": "操作",
        "sw": "auto",
        "x": 970,
        "y": 240,
        "wires": [
                "f9510104.f2b0e"
        "id": "f9510104.f2b0e",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "x": 1110,
        "y": 240,
        "wires": []
        "id": "72a893e.0d55c6c",
        "type": "ui_group",
        "name": "插座组",
        "tab": "1d6cc3f8.a0bbbc",
        "order": 2,
        "disp": true,
        "width": "6",
        "collapse": false
        "id": "1d6cc3f8.a0bbbc",
        "type": "ui_tab",
        "name": "我的家",
        "icon": "group",
        "order": 2,
        "disabled": false,
        "hidden": false
参与人数 3金钱 +45 HASS币 +20 收起 理由
userabc + 5 论坛有你更精彩!
+ 20 + 20 膜拜大神!
neroxps + 20 给力~
帖子
3709
Rank: 8Rank: 8
发表于 2019-3-27 13:03:04 | 显示全部楼层
赞一个,前排
帖子
7812
发表于 2019-3-27 13:06:15 | 显示全部楼层
这个插座还蛮好用的 想再入一个了
帖子
8580
Rank: 8Rank: 8
发表于 2019-3-27 21:38:09 | 显示全部楼层
控客,没怎么听过哦
帖子
3826
发表于 2019-4-12 19:29:44 | 显示全部楼层
玩不来。ui_switch那个,我导进去是错误的流程。
帖子
2046
Rank: 8Rank: 8
突出贡献
 楼主| 发表于 2019-4-12 21:20:29 | 显示全部楼层
node-red-dashboard装了么
帖子
3826
发表于 2019-4-12 23:41:00 | 显示全部楼层
感谢回复,确实没装,装上后没有异常提示了。用这个是不是要先把原来插件版的控客配置先注释掉。192.168.200.236这个是不是要换成自己的ha地址
帖子
2046
Rank: 8Rank: 8
突出贡献
 楼主| 发表于 2019-4-13 00:07:51 | 显示全部楼层
houhd 发表于 2019-4-12 23:41
感谢回复,确实没装,装上后没有异常提示了。用这个是不是要先把原来插件版的控客配置先注释掉。192.168.2 ...
你可以点击第一个留,也就是发现,用来发现自己具体的局域网控客插座
帖子
3826
发表于 2019-4-13 17:31:08 | 显示全部楼层
大佬,你好,感谢你热心回复。
我原先一直用插件的方式来接入控客插座的,
你这个流程我导入了,不过还是不会用。
帖子
2654
Rank: 6Rank: 6
发表于 2019-6-8 10:39:40 | 显示全部楼层
感谢大佬的的分享。请问这个能对接HA吗?HA的配置要怎么写?
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-5-21 04:11 , Processed in 0.255190 second(s), 36 queries .
Powered by Discuz! X3.4
