『瀚思彼岸』» 智能家居技术论坛
查看: 5270|回复: 4
[教程系列] Node red 安装home-assistant 报错!【已解决】
帖子
1153
Rank: 6Rank: 6
发表于 2018-10-14 00:09:20 | 显示全部楼层 |阅读模式
如题,Node-red 安装 home-assistant节点后 使用节点就报错小小白,表示看不懂!求各位大神求解!!!
重新移除后,重启,重新安装节点,就不报错了!原因不知道!!!
TypeError: Cannot read property 'getStates' of undefined
    at ConfigServerNode.getEntities (/home/pi/.node-red/node_modules/node-red-contrib-home-assistant/nodes/config-server/config-server.js:8:39)
    at Layer.handle [as handle_request] (/usr/lib/node_modules/node-red/node_modules/express/lib/router/layer.js:95:5)
    at next (/usr/lib/node_modules/node-red/node_modules/express/lib/router/route.js:137:13)
    at Route.dispatch (/usr/lib/node_modules/node-red/node_modules/express/lib/router/route.js:112:3)
    at /usr/lib/node_modules/node-red/node_modules/express/lib/router/index.js:281:22
    at Function.process_params (/usr/lib/node_modules/node-red/node_modules/express/lib/router/index.js:335:12)
    at next (/usr/lib/node_modules/node-red/node_modules/express/lib/router/index.js:275:10)
    at /usr/lib/node_modules/node-red/node_modules/express/lib/application.js:233:9
    at /usr/lib/node_modules/node-red/node_modules/express/lib/router/index.js:635:15
    at next (/usr/lib/node_modules/node-red/node_modules/express/lib/router/index.js:260:14)
    at expressInit (/usr/lib/node_modules/node-red/node_modules/express/lib/middleware/init.js:40:5)
    at trim_prefix (/usr/lib/node_modules/node-red/node_modules/express/lib/router/index.js:317:13)
    at /usr/lib/node_modules/node-red/node_modules/express/lib/router/index.js:284:7
帖子
3832
Rank: 8Rank: 8
发表于 2018-10-14 00:12:44 | 显示全部楼层
装完node节点重启下试试?
帖子
1153
Rank: 6Rank: 6
 楼主| 发表于 2018-10-14 00:17:48 | 显示全部楼层
令狐鸣 发表于 2018-10-14 00:12
装完node节点重启下试试?
重启过了,结果还是一样!
帖子
1153
Rank: 6Rank: 6
 楼主| 发表于 2018-10-14 00:19:27 | 显示全部楼层
TypeError: Cannot read property 'getServices' of undefined
    at ConfigServerNode.getServices (/home/pi/.node-red/node_modules/node-red-contrib-home-assistant/nodes/config-server/config-server.js:18:39)
帖子
Rank: 8Rank: 8
发表于 2018-10-14 16:45:48 | 显示全部楼层
看样子应该是homeassistant 的配置有问题吧?
这里应该是读服务器配置的数据。
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-5-20 22:53 , Processed in 0.664237 second(s), 26 queries .
Powered by Discuz! X3.4
