『瀚思彼岸』» 智能家居技术论坛
查看: 161|回复: 3
[求助] ha 不知道为啥?老停止服务
帖子
Rank: 1
发表于 2024-5-6 21:42:16 | 显示全部楼层 |阅读模式
跪求大佬帮忙看看拿的问题啊?
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
services-up: info: copying legacy longrun home-assistant (no readiness notification)
[13:35:11] INFO: Home Assistant Core finish process exit code 256
[13:35:11] INFO: Home Assistant Core finish process received signal 4
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
[13:36:17] INFO: Home Assistant Core finish process exit code 256
[13:36:18] INFO: Home Assistant Core finish process received signal 4
[13:37:24] INFO: Home Assistant Core finish process exit code 256
[13:37:24] INFO: Home Assistant Core finish process received signal 4
[13:38:31] INFO: Home Assistant Core finish process exit code 256
[13:38:31] INFO: Home Assistant Core finish process received signal 4
[13:39:37] INFO: Home Assistant Core finish process exit code 256
[13:39:37] INFO: Home Assistant Core finish process received signal 4
帖子
603
Rank: 4
发表于 2024-5-7 11:20:32 | 显示全部楼层
入门建议还是X86,每次官网推送的更新都能自动升级,省心啊
帖子
Rank: 1
 楼主| 发表于 2024-5-7 18:20:32 | 显示全部楼层
哥 有推荐的设备吗? 功耗也低越好
帖子
603
Rank: 4
发表于 2024-5-7 21:49:05 | 显示全部楼层
chp714 发表于 2024-5-7 18:20
哥 有推荐的设备吗? 功耗也低越好
J1900 小主机也就10w左右,比起安卓盒子也就高7w,多给点电费而已,稳定不易出问题比啥都强
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-6-2 22:02 , Processed in 0.315118 second(s), 25 queries .
Powered by Discuz! X3.4
