『瀚思彼岸』» 智能家居技术论坛
查看: 208|回复: 8
[技术探讨] 魔百盒使用docker安装haos这几天高级重新启动都需要20分钟
帖子
3860
Rank: 8Rank: 8
发表于 2024-5-6 00:22:26 | 显示全部楼层 |阅读模式
求助一下 大佬们这些天 高级重启和拔插魔百盒电源 启动好像刚刚安装haos一样需要等20分钟没有科学还需要等更加久兄弟们支招一下 是不是系统有问题重新安装也超级麻烦
INFO: Using udev information from host
INFO: Starting local supervisor watchdog...
[__main__] Initializing Supervisor setup
[supervisor.bootstrap] Setting up coresys for machine: qemuarm
[supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.04.4
[supervisor.docker.supervisor] Connecting Supervisor to hassio-network
[supervisor.resolution.evaluate] Starting system evaluation with state initialize
[supervisor.resolution.evaluate] System evaluation complete
[__main__] Setting up Supervisor
[supervisor.api] Starting API on 172.30.32.2
[supervisor.hardware.monitor] Started Supervisor hardware monitor
[supervisor.dbus.manager] Connected to system D-Bus.
[supervisor.dbus.agent] Load dbus interface io.hass.os
[supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
[supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
[supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
[supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
[supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
[supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
[supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
[supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
[supervisor.dbus.agent] No OS-Agent support on the host. Some Host functions have been disabled.
[supervisor.host.services] Updating service information
[supervisor.host.sound] Updating PulseAudio information
[supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
[supervisor.host.network] Updating local network information
[supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
[supervisor.docker.monitor] Started docker events monitor
[supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.04.1
[supervisor.plugins.cli] Starting CLI plugin
[supervisor.docker.manager] Cleaning hassio_cli application
[supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.04.1 - 172.30.32.5
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.04.0
[supervisor.plugins.dns] Starting CoreDNS plugin
[supervisor.docker.manager] Cleaning hassio_dns application
[supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.04.0 - 172.30.32.3
[supervisor.plugins.dns] Updated /etc/resolv.conf
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
[supervisor.plugins.audio] Starting Audio plugin
[supervisor.docker.manager] Cleaning hassio_audio application
[supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0
[supervisor.plugins.multicast] Starting Multicast plugin
[supervisor.docker.manager] Cleaning hassio_multicast application
[supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0 - Host
[supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemuarm-homeassistant with version landingpage
[supervisor.docker.manager] Cleaning homeassistant application
[supervisor.docker.manager] Removing image ghcr.io/home-assistant/qemuarm-homeassistant with latest
[supervisor.docker.manager] Removing image ghcr.io/home-assistant/qemuarm-homeassistant with landingpage
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemuarm-homeassistant with tag landingpage.
[supervisor.homeassistant.core] Starting HomeAssistant landingpage
[supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
[supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemuarm-homeassistant with version landingpage
[supervisor.os.manager] No Home Assistant Operating System found
[supervisor.store.data] Can't read translations from /data/addons/git/7eb31c6e/addons/hass_remote_cn/translations/en.yaml - expected a dictionary for dictionary value @ data['configuration']['key']
[supervisor.store.data] Can't read translations from /data/addons/git/7eb31c6e/addons/hass_remote/translations/en.yaml - expected a dictionary for dictionary value @ data['configuration']['key']
[supervisor.addons.validate] Add-on have full device access, and selective device access in the configuration. Please report this to the maintainer of Frigate (Full Access) Beta
[supervisor.store.git] Loading add-on /data/addons/git/6666f38d repository
[supervisor.store.git] Loading add-on /data/addons/git/ecaeb50e repository
[supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
[supervisor.store.git] Loading add-on /data/addons/git/b54ae9a0 repository
[supervisor.store.git] Loading add-on /data/addons/core repository
[supervisor.store.git] Loading add-on /data/addons/git/ccab4aaf repository
[supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
[supervisor.store.git] Loading add-on /data/addons/git/45df7312 repository
[supervisor.store.git] Loading add-on /data/addons/git/7eb31c6e repository
[supervisor.store] Loading add-ons from store: 95 all - 95 new - 0 remove
[supervisor.addons.manager] Found 3 installed add-ons
[supervisor.docker.interface] Attaching to homeassistant/armhf-addon-configurator with version 5.7.0
[supervisor.docker.interface] Attaching to homeassistant/armhf-addon-samba with version 12.1.0
[supervisor.docker.interface] Attaching to homeassistant/armhf-addon-ssh with version 9.8.1
[supervisor.backups.manager] Found 1 backup files
[supervisor.discovery] Loaded 0 messages
[supervisor.ingress] Loaded 0 ingress sessions
[supervisor.resolution.check] Starting system checks with state setup
[supervisor.resolution.checks.base] Run check for disabled_data_disk/system
[supervisor.resolution.checks.base] Run check for multiple_data_disks/system
[supervisor.resolution.check] System checks complete
[supervisor.resolution.evaluate] Starting system evaluation with state setup
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
[__main__] Running Supervisor
[supervisor.jobs] 'OSManager.mark_healthy' blocked from execution, no Home Assistant OS available
[supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
[supervisor.addons.manager] Phase 'system' starting 0 add-ons
[supervisor.addons.manager] Phase 'services' starting 0 add-ons
[supervisor.core] Skipping start of Home Assistant
[supervisor.addons.manager] Phase 'application' starting 0 add-ons
[supervisor.misc.tasks] All core tasks are scheduled
[supervisor.core] Supervisor is up and running
[supervisor.homeassistant.core] Home Assistant setup
[supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemuarm-homeassistant:landingpage to ghcr.io/home-assistant/qemuarm-homeassistant:2024.5.1
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemuarm-homeassistant with tag 2024.5.1.
[supervisor.host.info] Updating local host information
[supervisor.resolution.check] Starting system checks with state running
[supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
[supervisor.resolution.checks.base] Run check for pwned/addon
[supervisor.jobs] 'OSManager.reload' blocked from execution, no Home Assistant OS available
[supervisor.host.manager] Host information reload completed
[supervisor.resolution.checks.base] Run check for security/core
[supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
[supervisor.resolution.checks.base] Run check for free_space/system
[supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
[supervisor.resolution.checks.base] Run check for no_current_backup/system
[supervisor.resolution.module] Create new suggestion create_full_backup - system / None
[supervisor.resolution.module] Create new issue no_current_backup - system / None
[supervisor.resolution.checks.base] Run check for docker_config/system
[supervisor.resolution.checks.base] Run check for trust/supervisor
[supervisor.resolution.evaluate] Starting system evaluation with state running
[supervisor.resolution.fixup] Starting system autofix at state running
[supervisor.resolution.fixup] System autofix complete
帖子
5615
Rank: 8Rank: 8
发表于 2024-5-6 09:42:01 | 显示全部楼层
魔白盒这种东西最正确的安装应该是docker加core
帖子
573
Rank: 4
发表于 2024-5-6 13:09:16 | 显示全部楼层
早被那破盒子伤透了心,不就是一点电费的事儿嘛,上X86
帖子
3860
Rank: 8Rank: 8
 楼主| 发表于 2024-5-6 13:17:40 | 显示全部楼层
qxdnzx 发表于 2024-5-6 13:09
早被那破盒子伤透了心,不就是一点电费的事儿嘛,上X86,
n100跑 all in one 老是出问题 现在x86单独跑openwrt 莫百盒跑haos
帖子
3860
Rank: 8Rank: 8
 楼主| 发表于 2024-5-6 13:19:51 | 显示全部楼层
现在观察一下。重新启动armbian后查看 docker images镜像  一会他自动删掉ghcr.io/home-assistant/qemuarm-homeassistant       2024.5.1  然后重新下载 才可以启动
帖子
4092
发表于 2024-5-6 15:01:48 | 显示全部楼层
gmshiwoge 发表于 2024-5-6 13:19
现在观察一下。重新启动armbian后查看 docker images镜像  一会他自动删掉ghcr.io/home-assistant/qemuarm- ...
没错,当首次安装的话,会在线检查最新的版本,然后下载回来,如果没有科学,会很慢。
前面所有的控制逻辑,全是supervisor来进行的统一安排。其实就装机,直接让你装最新版。
如果你使用官方的HAOS在别的机器上装,就明白了,不管你预置了supervisor没有,它第一时间都检查最新版,然后先把自己升成最新,然后在检查别的是否最新,再全系升成最新版。从而保证你装完的,是当时最新的一套。
帖子
3860
Rank: 8Rank: 8
 楼主| 发表于 2024-5-6 17:02:19 | 显示全部楼层
前面所有的控制逻 ...
感觉和我升级了2024.4.4的Supervisor有关  情况和下吗github的issues差不多了   用得还不错就是reboot后每一次都是自动删掉Core镜像再下载
https://github.com/home-assistant/supervisor/issues/5050
帖子
4092
发表于 2024-5-6 17:11:30 | 显示全部楼层
gmshiwoge 发表于 2024-5-6 17:02
感觉和我升级了2024.4.4的Supervisor有关  情况和下吗github的issues差不多了   用得还不错就是reboot后 ...
从去年10月以后,HA是调整很多机制,加入代码检查等,同时也有内核和代码兼容性检查。
5月份版的版本,可能有一定的稳定期需要调整。这次的core,从5.0到5.1太快了,应该是改动有bug.
在正常使用时没事,但是安装就事多了。
像你这种情况,就是启动时候的supervisor对于系统健康检查的判断出错了。core再过一两个版本,就应该正常了。
帖子
3860
Rank: 8Rank: 8
 楼主| 发表于 2024-5-6 17:20:42 | 显示全部楼层
5月份版的版本,可 ...
哈哈哈  刚刚跟着这个教程https://github.com/home-assistan ... ?tab=readme-ov-file 重新安装一次系统 现在正常了
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-5-19 04:53 , Processed in 0.143886 second(s), 33 queries .
Powered by Discuz! X3.4
