『瀚思彼岸』» 智能家居技术论坛
楼主: hzcoolwind
[技术探讨] 某网DL集成版
帖子
1989
 楼主| 发表于 2024-4-26 11:39:30 来自手机 | 显示全部楼层
仅在docker 2024.3环境测试成功,其它环境需要各位自己适当修改调整
帖子
311
Rank: 3Rank: 3
发表于 2024-4-26 11:50:27 | 显示全部楼层
感谢分享,研究下~
帖子
1175
Rank: 6Rank: 6
发表于 2024-4-26 15:11:49 | 显示全部楼层
hzcoolwind 发表于 2024-4-26 11:37
第一步很关键python3.11 opencv,决定了密码登录是否正确
在docker版重新搭建,还是一样啊
帖子
1175
Rank: 6Rank: 6
发表于 2024-4-26 15:31:00 | 显示全部楼层
motoyu 发表于 2024-4-26 15:11
在docker版重新搭建,还是一样啊
帖子
1989
 楼主| 发表于 2024-4-26 15:35:57 | 显示全部楼层
短时间多次登录失败会被sgcc锁一天,明天再试试
帖子
1076
Rank: 6Rank: 6
发表于 2024-4-27 19:10:42 | 显示全部楼层
报错所有的都是未知
Logger: homeassistant.components.sensor
Source: helpers/entity_platform.py:575
Integration: 传感器 (documentation, issues)
First occurred: 17:40:26 (1 occurrences)
Last logged: 17:40:26
sgcc2024: Error on device update!
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 575, in _async_add_entity
    await entity.async_device_update(warning=False)
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 959, in async_device_update
    await self.async_update()
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 517, in async_update
    await self.coordinator.async_request_refresh()
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 250, in async_request_refresh
    await self._debounced_refresh.async_call()
  File "/usr/src/homeassistant/homeassistant/helpers/debounce.py", line 93, in async_call
    await task
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 276, in async_refresh
    await self._async_refresh(log_failures=True)
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 399, in _async_refresh
    self.async_update_listeners()
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 182, in async_update_listeners
    update_callback()
  File "/config/custom_components/sgcc2024/sensor.py", line 211, in _handle_coordinator_update
    value = data['accountinfo'][0]['dayNum']
KeyError: 'dayNum'
帖子
1989
 楼主| 发表于 2024-4-28 08:13:55 | 显示全部楼层
silang521 发表于 2024-4-27 19:10
报错所有的都是未知
看来各地的数据略有差异,这个是缺了预充值可用天数这个字段,自己稍微调整一下代码就可以了
帖子
1076
Rank: 6Rank: 6
发表于 2024-4-29 11:51:46 | 显示全部楼层
hzcoolwind 发表于 2024-4-28 08:13
看来各地的数据略有差异,这个是缺了预充值可用天数这个字段,自己稍微调整一下代码就可以了 ...
11111.png 没看懂代码不知道怎么修改,所有的都是未知和这个也有关系吗?
帖子
1989
 楼主| 发表于 2024-4-29 15:01:44 | 显示全部楼层
sensor 那个文件中把 包含 dayNum 那段删除也行, 这是最简单的处理方式,  这个位置其实是倒数第二个传感器了, 但这个异常会导致所有的传感器不更新
帖子
1076
Rank: 6Rank: 6
发表于 2024-4-29 15:24:29 | 显示全部楼层
hzcoolwind 发表于 2024-4-29 15:01
sensor 那个文件中把 包含 dayNum 那段删除也行, 这是最简单的处理方式,  这个位置其实是倒数第二个传感 ...
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-5-19 13:45 , Processed in 0.735472 second(s), 32 queries .
Powered by Discuz! X3.4
