『瀚思彼岸』» 智能家居技术论坛
查看: 627|回复: 1
[流程系列] 如何能在NodeRed中获取 XiaomiGateway3 蓝牙Mesh设备的消息?
帖子
Rank: 1
发表于 2023-9-3 20:36:47 | 显示全部楼层 |阅读模式
打开 xiaomigateway3的debug log可以看到mesh开关按下按键的消息,但是因为第几个按键是在 argments 参数里确定的,然后devices.py converter 里不知道该怎么处理。
有没有办法可以把这个消息扔到nodeRed, 处理起来就方便多了。
[MQTT] miio/report b'{"id":41147812,"method":"event_occured","params":{"did":"1081000262","siid":5,"eiid":1,"tid":247,"ts":1692885577,"arguments":[{"piid":2,"value":1}]},"type":16}'
[MQTT] central/report b'{"id":337529306,"_to":128,"type":16,"method":"event_occured","params":{"did":"1081000262","siid":5,"eiid":1,"tid":247,"ts":1692885577,"arguments":[{"piid":2,"value":1}]}}'
帖子
Rank: 1
 楼主| 发表于 2023-9-4 20:58:41 | 显示全部楼层
找到方法了,其实很简单,nodeRed 里连到 小米网关 ip的 mqtt server 就可以
https://github.com/AlexxIT/openmiio_agent
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-6-3 08:10 , Processed in 0.052397 second(s), 23 queries .
Powered by Discuz! X3.4
