『瀚思彼岸』» 智能家居技术论坛
查看: 853|回复: 2
M5Stack ATOM Matrix的esphome模板
帖子
1177
Rank: 6Rank: 6
发表于 2023-7-7 19:40:51 | 显示全部楼层 |阅读模式
最近买了个M5Stack ATOM Matrix,整体做工还行,有些小瑕疵,不影响。很迷你,挺喜欢,就是太贵了。
以下为接入代码,完全接入,并可在homeassistant中显示。红外需要自己添加设备,不过据说信号不行。
esphome:
  friendly_name: gradienter
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: ""
ota:
  password: "homeassistant"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Gradienter"
captive_portal:
i2c:
  sda: 25
  scl: 21
  scan: true
  - platform: mpu6886
    i2c_id: bus_a
    address: 0x68
    update_interval: 1s
    accel_x:
      name: "MPU6886 Accel X"
    accel_y:
      name: "MPU6886 Accel Y"
    accel_z:
      name: "MPU6886 Accel z"
    gyro_x:
      name: "MPU6886 Gyro X"
    gyro_y:
      name: "MPU6886 Gyro Y"
    gyro_z:
      name: "MPU6886 Gyro z"
    temperature:
      name: "MPU6886 Temperature"
binary_sensor:
  - platform: gpio
    pin: 39
light:
  - platform: esp32_rmt_led_strip
    rgb_order: GRB
    pin: 27
    num_leds: 25
    rmt_channel: 1
    chipset: ws2812
    effects:
      # Customize parameters
      - random:
          name: "My Slow Random Effect"
          transition_length: 30s
          update_interval: 30s
      - random:
          name: "My Fast Random Effect"
          transition_length: 4s
          update_interval: 5s
      - pulse:
          transition_length: 0.5s
          update_interval: 0.5s
          min_brightness: 0%
          max_brightness: 100%
      - pulse:
          # transition_length: 1s      # defaults to 1s
          update_interval: 2s
      - random:
          name: Random Effect With Custom Values
          transition_length: 5s
          update_interval: 7s
      - strobe:
          name: Strobe Effect With Custom Values
          colors:
            - state: true
              brightness: 100%
              red: 100%
              green: 90%
              blue: 0%
              duration: 500ms
            - state: false
              duration: 250ms
            - state: true
              brightness: 100%
              red: 0%
              green: 100%
              blue: 0%
              duration: 500ms
      - flicker:
          name: Flicker Effect With Custom Values
          alpha: 95%
          intensity: 1.5%
      - addressable_rainbow:
          name: Rainbow Effect With Custom Values
          speed: 10
          width: 50
      - addressable_color_wipe:
          # name: Color Wipe Effect With Custom Values
          # colors:
          #   - red: 100%
          #     green: 100%
          #     blue: 100%
          #     num_leds: 1
          #   - red: 0%
          #     green: 0%
          #     blue: 0%
          #     num_leds: 1
          # add_led_interval: 100ms
          # reverse: false
      - addressable_scan:
          name: Scan Effect With Custom Values
          move_interval: 100ms
          scan_width: 1
      - addressable_twinkle:
          name: Twinkle Effect With Custom Values
          twinkle_probability: 5%
          progress_interval: 4ms
      - addressable_random_twinkle:
          name: Random Twinkle Effect With Custom Values
          progress_interval: 32ms
      - addressable_fireworks:
          name: Fireworks Effect With Custom Values
          update_interval: 32ms
          spark_probability: 10%
          use_random_color: false
          fade_out_rate: 120
remote_transmitter:
  pin: GPIO12
  carrier_duty_percent: 50%
帖子
1177
Rank: 6Rank: 6
 楼主| 发表于 2023-7-7 19:44:25 | 显示全部楼层
分别接入了加速度计、角速度计,按钮,5*5灯板,红外。剩下的外围接口或者外围设备自行添加。
帖子
610
Rank: 4
发表于 2023-8-10 09:36:10 | 显示全部楼层
这个功能太好了
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-5-26 03:05 , Processed in 0.096658 second(s), 24 queries .
Powered by Discuz! X3.4
