『瀚思彼岸』» 智能家居技术论坛
查看: 19409|回复: 414
[UI界面] 记录南方电网集成UI界面使用(sensor和apexcharts-card卡片)
帖子
1172
发表于 2023-7-3 01:13:05 | 显示全部楼层 |阅读模式
cubicpil大大的南方电网电费数据HA集成(https://bbs.hassbian.com/thread-18578-1-1.html),免除我原来的电费接入的麻烦,但使用下来和自己习惯还是有点差别,所以自己微微优化了一下。
更改了一下传感器的代码,让每月1号不会显示错误
一、增加“上月电费”和"用电历史记录"两个传感器
  "用电历史记录"增加history_day_value属性,为上月的用电记录和本月用电记录合并(最主要用来查看最近30天用电记录,原集成的sensor.XXXXXXXXXXXX_latest_day_kwh用apexcharts-card卡片显示时不好用,sensor.XXXXXXXXXXXX_this_month_total_usage又只能看到当月,如果是在月初,只能看到几天的,不习惯)
二、UI界面显示
type: vertical-stack
cards:
  - type: horizontal-stack
    title: 用电状态
    cards:
      - type: sensor
        entity: sensor.XXXXXXXXXXXX_this_month_total_usage
        icon: mdi:home-lightning-bolt-outline
      - hours_to_show: 24
        graph: none
        type: sensor
        entity: sensor.XXXXXXXXXXXX_latest_day_kwh
        detail: 1
      - hours_to_show: 24
        graph: none
        type: sensor
        entity: sensor.XXXXXXXXXXXX_arrears
        detail: 1
        icon: mdi:currency-jpy
        unit: 元
    cards:
      - type: sensor
        entity: sensor.XXXXXXXXXXXX_last_month_total_usage
      - hours_to_show: 24
        graph: none
        type: sensor
        entity: sensor.airpowerheatertemperature
        detail: 1
        unit: 元
    cards:
      - type: sensor
        entity: sensor.XXXXXXXXXXXX_this_year_total_usage
      - hours_to_show: 24
        graph: none
        type: sensor
        entity: sensor.XXXXXXXXXXXX_this_year_total_cost
        detail: 1
        unit: 元
    cards:
      - type: sensor
        entity: sensor.XXXXXXXXXXXX_last_year_total_usage
      - hours_to_show: 24
        graph: none
        type: sensor
        entity: sensor.XXXXXXXXXXXX_last_year_total_cost
        detail: 1
        unit: 元
    cards:
      - type: custom:apexcharts-card
        header:
          show: true
          title: 30天用电与费用趋势图
        graph_span: 30d
        span:
          start: day
          offset: '-30d'
        series:
          - entity: sensor.history_day
            type: column
            color: rgb(51,153,255)
            attribute: history_day_value
            data_generator: |
              return entity.attributes.history_day_value.map(entry => {
                return {
                  x: entry.date,
                  y: entry.kwh
            color: rgb(255,153,0)
            data_generator: |
                return {
                  x: entry.date,
                  y: entry.kwh*0.65886875
参与人数 7金钱 +60 收起 理由
cooliscool + 5
has6688 + 2
cubicpill + 16 厉害了word楼主!
depboy + 12 高手,这是高手!
CCCmei + 5 膜拜大神!
sorrypqa + 10 大神666!
隔壁的王叔叔 + 10 高手,这是高手!
帖子
3570
Rank: 8Rank: 8
发表于 2023-7-3 01:49:13 | 显示全部楼层
高手啊,膜拜下
帖子
1136
Rank: 6Rank: 6
发表于 2023-7-3 08:04:58 来自手机 | 显示全部楼层
我添加后怎么出错呢
帖子
173
Rank: 2
发表于 2023-7-3 09:34:54 | 显示全部楼层
感谢分享,学习一下
帖子
2192
Rank: 6Rank: 6
发表于 2023-7-3 09:36:51 | 显示全部楼层
老哥,这卡牌很好看,国网的能搞个吗
帖子
38
Rank: 1
发表于 2023-7-3 09:39:24 | 显示全部楼层
非常好,学习了
帖子
238
Rank: 3Rank: 3
发表于 2023-7-3 10:21:37 | 显示全部楼层
感谢分享,学习一下
帖子
118
Rank: 2
发表于 2023-7-3 11:34:58 | 显示全部楼层
我的还是登录了  没内容
帖子
204
Rank: 3Rank: 3
发表于 2023-7-3 12:32:29 | 显示全部楼层
强大,学习,谢谢
帖子
174
Rank: 2
发表于 2023-7-3 12:54:06 | 显示全部楼层
感谢分享,学习一下
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-5-6 04:55 , Processed in 0.061477 second(s), 35 queries .
Powered by Discuz! X3.4
