『瀚思彼岸』» 智能家居技术论坛
楼主: 121665460
[插件集成] 【HomeAssistant国内版客户端】gps定位,地理位置,通知,更新
帖子
905
Rank: 4
发表于 2022-11-24 12:43:15 | 显示全部楼层
是真好用
帖子
124
Rank: 2
发表于 2022-11-25 08:37:18 | 显示全部楼层
帖子
428
Rank: 3Rank: 3
发表于 2022-11-25 09:56:23 | 显示全部楼层
楼主辛苦了,谢谢楼主,感谢楼主分享,楼主好人一生平安!!!
帖子
4582
 楼主| 发表于 2022-11-25 14:15:52 | 显示全部楼层
2022-11-25版本
合并官方2022.11.0版本代码:
  • Android 13 notification changes + target by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#2682
  • Add notify command for app-lock by [color=var(--color-fg-default)]@RoboMagus in [color=var(--color-accent-fg)]#2868
  • Use compressed entity changes for device controls by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#2942
  • Update filter in Manage Sensors to all/enabled/disabled by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#2950
  • Clean up spacing in BLE transmitter description by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#2952
  • Add permissions requests to wear OS sensors and add network sensors by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#2956
  • Don't use a hardcoded list of apps for Wear OS detection by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#2958
  • Update deprecated onBackPressed, support predictive back gesture by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#2959
  • Add a screen off timeout sensor and command for control by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#2960
  • Fix permission requests for beacon monitor by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#2964
  • Improve settings when using Home Assistant Cloud by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#2965
  • Show settings chip while loading Wear app by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#2968
  • Bump gradle from 7.3.0 to 7.3.1 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#2967
  • Bump com.github.ben-manes.versions from 0.42.0 to 0.43.0 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#2971
  • Bump actions/setup-java from 3.5.1 to 3.6.0 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#2975
  • Breaking Change: Fix mobile data roaming sensor after target SDK change by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#2978
  • Settings activity app lock by [color=var(--color-fg-default)]@RoboMagus in [color=var(--color-accent-fg)]#2926
  • Bump iconics-compose from 5.3.4 to 5.4.0 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#2943
  • Add On Body sensor for Wear OS by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#2961
  • Bump iconics-core from 5.3.4 to 5.4.0 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#2945
  • Bump community-material-typeface from 6.4.95.0-kotlin to 7.0.96.0-kotlin by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#2944
  • Support zone name only location tracking by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#2969
  • Tweak onboarding design to be more unified by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#2979
  • Add more Wear OS sensors by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#2981
  • Change log 10/21 by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#2983
  • Improve monochrome icon by [color=var(--color-fg-default)]@Dubzer in [color=var(--color-accent-fg)]#2980
  • Convert Play tasks to coroutines by [color=var(--color-fg-default)]@NotWoods in [color=var(--color-accent-fg)]#2962
  • Add previews to Wear OS compose and sort sensor by name by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#2984
  • Make more onboarding screens scrollable by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#2987
  • Fix navigation bar color on OnboardingActivity by [color=var(--color-fg-default)]@TylerCarberry in [color=var(--color-accent-fg)]#2988
  • Revert/set force dark again for webview by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#2989
  • Remove dependency that caused beta to fail to publish. by [color=var(--color-fg-default)]@JBassett in [color=var(--color-accent-fg)]#2991
  • Add Wet Mode Sensor by [color=var(--color-fg-default)]@SkechyWolf in [color=var(--color-accent-fg)]#2994
  • Bump bruceadams/get-release from 1.2.3 to 1.3.1 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#2996
  • Bump sentry-android from 6.5.0 to 6.6.0 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#2998
  • Add user activity sensor from health services for Wear OS by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#2995
  • Bump play services location tracking and move away from deprecated methods by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#2999
  • Fix global vars in bedtime and theater mode by [color=var(--color-fg-default)]@SkechyWolf in [color=var(--color-accent-fg)]#3001
  • Add database checks to PR workflow by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#3000
  • Remove unused setters by [color=var(--color-fg-default)]@NotWoods in [color=var(--color-accent-fg)]#3002
  • Set focus for onboarding activity to support rotary input by [color=var(--color-fg-default)]@StopMotionCuber in [color=var(--color-accent-fg)]#3009
  • Bump bruceadams/get-release from 1.3.1 to 1.3.2 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#3004
  • Bump reorderable from 0.9.2 to 0.9.4 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#3007
  • Add a heart rate sensor to Wear OS by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#3008
  • Bump firebase-appdistribution-gradle from 3.0.3 to 3.1.0 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#3011
  • Update change log 10/28 by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#3013
  • Only use internal URL when data is also using Wi-Fi by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#3015
  • Change DocsLink in Wear OS Sensors by [color=var(--color-fg-default)]@SkechyWolf in [color=var(--color-accent-fg)]#3017
  • Catch Geocoder exceptions on Android 13 by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#3021
  • Only resume once for websocket message responses by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#3023
  • Don't check Wifi SSID when home wifi list is empty by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#3025
  • Increase notification video attachment GIF length by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#3027
  • Fix location updates on core <2022.2 by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#3030
  • Don't log full exception with no Wear app installed by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#3031
  • Bump and switch to compose BOM dependency by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#3028
  • Bump accompanist-appcompat-theme from 0.25.1 to 0.27.0 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#2997
  • Revert reorderable bump until upstream issue is fixed by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#3035
  • Add caching of favorites in Wear OS, resulting in prettier loading by [color=var(--color-fg-default)]@mads03dk in [color=var(--color-accent-fg)]#2982
  • Add daily floors sensor for Wear OS3 devices by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#3005
  • Track time between hardware sensor updates to restart the listener as needed by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#3026
  • Remove unneeded kotlin option by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#3039
  • Add missing boot completed permission for Wear OS by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#3042
  • Catch exceptions while sending websocket messages by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#3046
  • Remove quick bar deprecation comment by [color=var(--color-fg-default)]@chriss158 in [color=var(--color-accent-fg)]#3052
  • Bump jackson-module-kotlin from 2.13.4 to 2.14.0 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#3048
  • Bump sentry-android from 6.6.0 to 6.7.0 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#3049
  • Switch from viewModelScope to lifecycleScope for external collections by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#3045
  • Add Daily Calories, Distance and Steps sensors for health services by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#3054
  • Bump location dependency by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#3056
  • Bump reorderable from 0.9.2 to 0.9.5 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#3055
  • Update change log week of 11/11 by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#3058
  • Make active websocket message tracking thread-safe by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#3061
  • Revert jackson-module-kotlin bump to fix compatibility on older Android version by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#3077
  • Store health services updates and send them with worker updates by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#3076
  • Bump hilt-android-gradle-plugin from 2.44 to 2.44.2 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#3070
  • Bump hilt-android-compiler from 2.44 to 2.44.2 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#3072
  • Bump com.github.ben-manes.versions from 0.43.0 to 0.44.0 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#3068
  • Bump hilt-android from 2.44 to 2.44.2 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#3071
  • Add proper device class for daily distance sensor on Wear OS3 by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#3079
  • Update and fix in-app language picker by [color=var(--color-fg-default)]@jpelgrom in [color=var(--color-accent-fg)]#3080
  • Skip heart rate value updates when below 0 by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#3081
  • Bump reorderable from 0.9.5 to 0.9.6 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#3064
  • Reduce usage of job scheduling to avoid throttling by [color=var(--color-fg-default)]@dshokouhi in [color=var(--color-accent-fg)]#3087
  • Bump firebase-appdistribution-gradle from 3.1.0 to 3.1.1 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#3082
  • Bump accompanist-appcompat-theme from 0.27.0 to 0.27.1 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#3085
  • Bump sentry-android from 6.7.0 to 6.8.0 by [color=var(--color-fg-default)]@dependabot in [color=var(--color-accent-fg)]#3089
  • Update a bunch of Github Actions by [color=var(--color-fg-default)]@JBassett in [color=var(--color-accent-fg)]#3092
帖子
6440
Rank: 8Rank: 8
发表于 2022-11-25 14:16:53 | 显示全部楼层
话说能不能,把app里面有些英文的也翻译成中文
帖子
406
Rank: 3Rank: 3
发表于 2022-11-25 14:20:36 | 显示全部楼层
感谢大佬
帖子
4582
 楼主| 发表于 2022-11-25 14:22:41 | 显示全部楼层
下版本看时间处理
帖子
580
Rank: 4
发表于 2022-11-25 14:28:03 | 显示全部楼层
感谢分享,非常好用!
帖子
6440
Rank: 8Rank: 8
发表于 2022-11-25 14:54:10 | 显示全部楼层
121665460 发表于 2022-11-25 14:22
下版本看时间处理
论坛有你更精彩
帖子
702
Rank: 4
发表于 2022-11-25 15:41:56 | 显示全部楼层
!!!!!又更新了吗!
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-9-21 09:25 , Processed in 0.059606 second(s), 30 queries .
Powered by Discuz! X3.4
