『瀚思彼岸』» 智能家居技术论坛
查看: 7921|回复: 75
[经验分享] 某动X12空调伴侣esphome固件分享 2023.6.24 更新功率部分
帖子
2511
Rank: 6Rank: 6
发表于 2022-8-9 14:52:32 | 显示全部楼层 |阅读模式
时隔久远,看有回帖编译失败的,于是编译了一个
x12_remote.zip (333.8 KB, 下载次数: 28)
放上来,需要自取
天热想起空调了,更新一波吧(yaml附件,请移步46楼)
某动X12空调伴侣,刷入esphome固件,再配置 ryanh7大佬 插件,可完美接入ha
Smartac+esphome 理论上兼容200多种品牌老空调
插件地址:
https://bbs.hassbian.com/thread-15867-1-1.html
使用方法:
https://bbs.hassbian.com/thread-15827-1-1.html
可惜我家的whirlpool还是不能用,自己不能用,就分享给朋友们吧。
核心代码如下了,太长贴不全,还有之前分享的在二楼,组合起来,应该可以完美使用了。
substitutions:
  plug_name: x12_remote_1
  # Higher value gives lower watt readout
  current_res: "0.005"
  # Lower value gives lower voltage readout
  voltage_div: "369" # 369
esphome:
  platform: ESP8266
  board: esp_wroom_02
  on_boot:
    priority: 600
    then:
      - lambda: |-
            id(Voltage).publish_state(id(y_voltage).state + 116.3);
            id(Amperage).publish_state(id(Wattage).state / (id(y_voltage).state + 116.3) );
            id(ctrl_text).publish_state("若然,一切若然~");
wifi:
  ssid: !secret wifi_2 # wifi_ssid
  manual_ip:
    static_ip: 192.168.3.207
    gateway: 192.168.3.254
    subnet: 255.255.255.0
    dns1: 192.168.3.254
  ap:
    ssid: "x12_remote_1_Hotspot"
    password: !secret fallwifi_pswd
captive_portal:
# Enable logging
logger:
  level: debug #makes uart stream available in esphome logstream
  # baud_rate: 0 #disable logging over uart
# Enable Home Assistant API
api:
  password: !secret api_password
  services:
    - service: send_raw_command
      variables:
        command: int[]
      then:
        - remote_transmitter.transmit_raw:
            code: !lambda 'return command;'
            carrier_frequency: 38k
    - service: ctrl_text
      variables:
        target: string
      then:
        - lambda: |-
            id(ctrl_text).publish_state(target);
ota:
  password: !secret ota_password
web_server:
  port: 80
time:
  - platform: sntp
  - platform: hlw8012
    sel_pin:
      number: 12
      inverted: True
    cf_pin: 4
    cf1_pin: 5
    #current_resistor: ${current_res}
    voltage_divider: ${voltage_div}
    # current:
    #   name: "${plug_name}_Amperage"
    #   unit_of_measurement: A
    voltage:
      unit_of_measurement: V
    power:
      unit_of_measurement: W
    update_interval: 10s
    initial_mode: VOLTAGE    # VOLTAGE 或 CURRENT
    change_mode_every: 8  #默认8 # 4294967295
  - platform: template
    icon: "mdi:sine-wave"
    icon: "mdi:current-ac"
  - platform: total_daily_energy
    power_id: "Wattage"
    filters:
        # Multiplication factor from W to kW is 0.001
        - multiply: 0.001
    unit_of_measurement: kWh
# Extra sensor to keep track of plug uptime
  - platform: uptime
  - platform: uptime
binary_sensor:
    device_class: power
interval:
  - interval: 3s #定时
    then:
      - lambda: |-
            if( id(Wattage).state > 3){
              id(Power).publish_state(true);
              if(id(led_switch).state){
                id(led).turn_on();
            }else{
              id(Power).publish_state(false);
              id(led).turn_off();
remote_receiver:
  pin:
    number: 13 #接收
    inverted: True
  #dump: nec
  dump: all
remote_transmitter:
  pin:
    number: 14 #发射
  carrier_duty_percent: 50%
参与人数 1金钱 +8 收起 理由
ruike007 + 8 论坛有你更精彩!
若然,一切若然~
帖子
2511
Rank: 6Rank: 6
 楼主| 发表于 2022-8-9 14:55:04 | 显示全部楼层
esphome:
esp8266:
  board: esp01_1m
api:
  password: "yiqieruoran"
  services:
      variables:
        command: int[]
      then:
            carrier_frequency: 38kHz
ota:
  password: "yiqieruoran" # 一切若然
wifi:
  # ssid: "ssid"
  # password: "yiqieruoran" # 一切若然
  ap:
    ssid: "X12-Test_Hotspot"
captive_portal:
# Enable logging
logger:
  # level: VERBOSE #makes uart stream available in esphome logstream
# web_server:
#   port: 80
remote_receiver:
  pin:
    number: 13 #接收
    inverted: True
  #dump: nec
  dump: all
remote_transmitter:
  pin:
    number: 14 #发射
switch:
  - platform: gpio
    pin: 15
    inverted: false
若然,一切若然~
帖子
546
Rank: 4
发表于 2022-8-9 15:05:04 来自手机 | 显示全部楼层
谢谢分享,占位
帖子
161
Rank: 2
发表于 2022-8-9 15:15:44 | 显示全部楼层
支持一下,感谢分享
帖子
1216
Rank: 6Rank: 6
发表于 2022-8-9 15:30:54 | 显示全部楼层
帖子
7830
发表于 2022-8-9 16:25:24 | 显示全部楼层
X12有个功率计
帖子
55
Rank: 2
发表于 2023-1-16 14:31:25 | 显示全部楼层
支持一下,感谢分享
帖子
85
Rank: 2
发表于 2023-6-23 15:46:11 | 显示全部楼层
刷这个固件 功率计是不是就没有用了额啊?
帖子
85
Rank: 2
发表于 2023-6-23 19:21:09 | 显示全部楼层
膜拜大神,补了半天得课,也没有想明白到底应该怎么弄  ,现在连python环境还没有搭建好,我是不是可以放弃了、、、、、
帖子
2511
Rank: 6Rank: 6
 楼主| 发表于 2023-6-24 10:52:03 | 显示全部楼层
把功率部分也补上了,一楼已更新了
若然,一切若然~
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-6-2 20:26 , Processed in 0.123753 second(s), 36 queries .
Powered by Discuz! X3.4
