『瀚思彼岸』» 智能家居技术论坛
楼主: riceball
[修仙教程] ESP32c3 刷 ESPHome 简要指南
帖子
549
Rank: 4
发表于 2022-7-30 10:29:43 | 显示全部楼层
用arduino框架,不能配置gpio12,gpio13,就合宙这个板子自带的两颗LED,提示这个
,需要如何处理?谢谢
帖子
549
Rank: 4
发表于 2022-7-30 10:30:53 | 显示全部楼层
看不到图片么
帖子
549
Rank: 4
发表于 2022-7-30 10:32:31 | 显示全部楼层
真惭愧,不会发图,预览显示有,发出来就没了
帖子
549
Rank: 4
发表于 2022-7-30 10:34:24 | 显示全部楼层
复制文本吧,This pin cannot be used on ESP32-C3s and is already used by the SPI/PSRAM interface (function: SPIHD).
字面意思是SPI占用了,实际肯定是没有的
帖子
672
Rank: 4
发表于 2022-10-22 18:53:50 | 显示全部楼层
ESP32-C3-WROOM-02-N4 不能用楼主的代码吗?
烧录成功但开不起来
esphome:
esphome:
  platformio_options:
    board_build.flash_mode: dio
esp32:
  board: esp32-c3-devkitm-1
  variant: ESP32C3
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "68b64a6330bc2c4b3b47ce5aca4915f1"
wifi:
  ssid: !secret wifi_ssid
  # Enable fallback hotspot in case wifi connection fails
  ap:
    ssid: "Test Fallback Hotspot"
    password: "rUMCwmAUUZCb"
串口信息:
ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x1 (POWERON),boot:0xd (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd6100,len:0x19a0
load:0x403ce000,len:0x8d4
load:0x403d0000,len:0x2dc0
entry 0x403ce000
I (30) boot: ESP-IDF 4.3.2 2nd stage bootloader
I (30) boot: compile time 18:37:29
I (30) boot: chip revision: 3
I (32) boot_comm: chip revision: 3, min. bootloader chip revision: 0
I (39) boot.esp32c3: SPI Speed      : 80MHz
I (44) boot.esp32c3: SPI Mode       : DIO
I (48) boot.esp32c3: SPI Flash Size : 4MB
I (53) boot: Enabling RNG early entropy source...
I (58) boot: Partition Table:
I (62) boot: ## Label            Usage          Type ST Offset   Length
I (69) boot:  0 nvs              WiFi data        01 02 00009000 00004000
I (77) boot:  1 otadata          OTA data         01 00 0000d000 00002000
I (84) boot:  2 phy_init         RF data          01 01 0000f000 00001000
I (92) boot:  3 app0             OTA app          00 10 00010000 001c0000
I (99) boot:  4 app1             OTA app          00 11 001d0000 001c0000
I (107) boot: End of partition table
I (111) boot: No factory image, trying OTA 0
I (116) boot_comm: chip revision: 3, min. application chip revision: 0
I (123) esp_image: segment 0: paddr=00010020 vaddr=3c090020 size=1b8e0h (112864) map
I (149) esp_image: segment 1: paddr=0002b908 vaddr=3fc8de00 size=031f8h ( 12792) load
I (151) esp_image: segment 2: paddr=0002eb08 vaddr=40380000 size=01510h (  5392) load
I (155) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=813b4h (529332) map
I (242) esp_image: segment 4: paddr=000b13dc vaddr=40381510 size=0c764h ( 51044) load
I (252) esp_image: segment 5: paddr=000bdb48 vaddr=50000000 size=00010h (    16) load
I (256) boot: Loaded app from partition at offset 0x10000
I (298) boot: Set actual ota_seq=1 in otadata[0]
I (298) boot: Disabling RNG early entropy source...
I (309) cpu_start: Pro cpu up.
I (321) cpu_start: Pro cpu start user code
I (321) cpu_start: cpu freq: 160000000
I (322) cpu_start: Application information:
I (324) cpu_start: Project name:     c3test
I (329) cpu_start: App version:      2022.10.0
I (334) cpu_start: Compile time:     Oct 22 2022 18:37:01
I (340) cpu_start: ELF file SHA256:  c0ca18b8e35d91bc...
I (346) cpu_start: ESP-IDF:          4.3.2
I (351) heap_init: Initializing. RAM available for dynamic allocation:
I (358) heap_init: At 3FC95890 len 0002A770 (169 KiB): DRAM
I (364) heap_init: At 3FCC0000 len 0001F060 (124 KiB): STACK/DRAM
I (371) heap_init: At 50000010 len 00001FF0 (7 KiB): RTCRAM
I (378) spi_flash: detected chip: generic
I (382) spi_flash: flash io: dio
I (387) sleep: Configure to isolate all GPIO pins in sleep state
Terminal disconnected: FramingError: A framing error has been detected.
帖子
672
Rank: 4
发表于 2022-10-22 23:39:45 | 显示全部楼层
烧录成功但开不起来
是esphome view log webui的問題
改用esphome flasher看logs是正常的
帖子
114
Rank: 2
发表于 2023-4-7 18:31:20 | 显示全部楼层
yyddyym 发表于 2022-7-30 10:29
用arduino框架,不能配置gpio12,gpio13,就合宙这个板子自带的两颗LED,提示这个,需要如何处理?谢谢 ...
请问最后解决了吗,如何解决的
帖子
62
Rank: 2
发表于 2023-8-10 15:30:27 | 显示全部楼层
You can modified the esphome source file: https://github.com/esphome/espho ... 32/gpio_esp32_c3.py remove line 11 and 12:
_ESP32C3_SPI_PSRAM_PINS = {
#    12: "SPIHD",
#    13: "SPIWP",
    14: "SPICS0",
    15: "SPICLK",
    16: "SPID",
    17: "SPIQ",
只能改到自己的库里面保存,但是不知道怎么在yaml里设置使用
帖子
62
Rank: 2
发表于 2023-8-11 21:12:57 | 显示全部楼层
luatos ESP32C3-CORE开发板(简版)使用GPIO12,13编译报错。This pin cannot be used on ESP32-C3s and is already used by the SPI/PSRAM interface。有没有什么方法解决?
帖子
366
Rank: 3Rank: 3
发表于 2023-9-29 00:34:45 | 显示全部楼层
richard695 发表于 2023-8-10 15:30
You can modified the esphome source file: https://github.com/esphome/esphome/blob/dev/esphome/compon ...
借鉴你的提示,用esphome的命令行版,正常启用了GPIO12和13.
感谢感谢!
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-6-2 13:59 , Processed in 0.099760 second(s), 30 queries .
Powered by Discuz! X3.4
