『瀚思彼岸』» 智能家居技术论坛
楼主: riceball
自制开源ESPHome通用蓝牙网关(ESP32)
帖子
2873
Rank: 6Rank: 6
发表于 2022-5-19 21:16:10 | 显示全部楼层
riceball 发表于 2022-5-19 20:37
我的意思是HA上找不到蓝牙适配器硬件, 所以 bt_interface 是 disable 的(没激活的)
你是在 docker 容器 ...
是在主机和容器都能执行。
容器里是不是要授权?但是我进入容器输入官方那两条命令是错误的命令,应该怎么用?
帖子
2873
Rank: 6Rank: 6
发表于 2022-5-20 02:45:17 | 显示全部楼层
我删除ui集成,用yaml模式配置hci0,可以扫描到usb蓝牙适配器下的设备了。
ble_monitor:
  hci_interface:
    - 0
  bt_auto_restart: True
  discovery: True
  devices:
    - mac: 'E8:FE:8B:ED:4F:09'
    - mac: 'A4:C1:38:FF:37A'
    - mac: 'B8:7C:6F:32:95F'
但是esphome网关还不行,两者可以共存吗?还是只能用一种方式?
帖子
1508
 楼主| 发表于 2022-5-20 08:38:21 | 显示全部楼层
ble_monitor:
  hci_interface:
1. esphome网关如何不行?  detail
2. 可以共存.
帖子
1508
 楼主| 发表于 2022-5-20 08:40:05 | 显示全部楼层
nucleic_acid 发表于 2022-5-19 12:10
刚才看了你之前的帖子
使用Passive BLE Monitor集成代替蓝牙网关直接接入HA
`重启后恢复状态` 如果没有勾选,那么重启后在没有收到广播前,设备状态为 `Unavailable`.
帖子
2873
Rank: 6Rank: 6
发表于 2022-5-20 12:46:41 | 显示全部楼层
esp32编译烧录正常,启动后有扫描到设备日志。ha没有自动扫描添加实体
配置如下
esphome:
substitutions:
  # Name the device and it's entities
  device: ble_gateway
  device_name: ble_gateway4
esphome:
  comment: $device
  platformio_options:
    board_build.flash_mode: dio
esp32:
  board: nodemcu-32s
  framework:
    type: arduino
    version: 2.0.2
    platform_version: https://github.com/tasmota/platform-espressif32/releases/download/v2.0.2.3/platform-espressif32-2.0.2.3.zip
external_components:
  - source: github://myhomeiot/esphome-components
esp32_ble_tracker:
# Enable logging
logger:
web_server:
  port: 80
# Enable Home Assistant API
api:
  reboot_timeout: 1h
ota:
  password: "wxb1984626**"
wifi:
  ssid: "XXX"
  password: "XXX"
#  manual_ip:
#    static_ip: "192.168.2.41"
#    gateway: "192.168.2.1"
#    subnet: "255.255.255.0"
#    dns1: "192.168.2.1"
  # Enable fallback hotspot in case wifi connection fails
  ap:
    ssid: "4fblegateway"
    password: "XXX"
ble_gateway:
#  devices:
#     - mac_address: B8:7C:6F:32:95:DF
  #   - mac_address: !secret lywsd03mmc_mac
  on_ble_advertise:
    then:
      - homeassistant.service:
          service: ble_monitor.parse_data
          data:
            packet: !lambda return packet;
            gateway_id: $device_name
      - homeassistant.event:
          event: esphome.on_ble_advertise
          data:
text_sensor:
  - platform: homeassistant
    entity_id: binary_sensor.ble_gateway
    attribute: devices
    on_value:
      then:
        lambda: id($device_name).set_devices(x);
ha configuration.yaml:
配置相同
ha automations.yaml
- id: '1652780647472'
  alias: HA Start automation
  trigger:
    event: start
  action:
    service: input_boolean.turn_on
    entity_id: input_boolean.ha_started
  initial_state: true
帖子
1508
 楼主| 发表于 2022-5-20 19:19:47 | 显示全部楼层
配置如下
esphome:
你没注意看我给你的回复, `重启后恢复状态` 是我回复别人的.
esphome 网关不会发现添加设备, 你必须手动在ble_monitor集成中添加.
自动发现添加只能在ble_monitor集成上的蓝牙适配器上完成.
帖子
2873
Rank: 6Rank: 6
发表于 2022-5-20 21:17:44 | 显示全部楼层
esphome 网关不会发现添加设备, 你必须手动 ...
我用了官方的配置,自动发现也可以了,感谢回复
帖子
200
发表于 2022-5-21 14:17:28 | 显示全部楼层
我想问下,你们使用 ble monitor 会不会不稳定,偶尔会有这条日志
HCIdump thread: Something wrong - interface hci0 not ready, and will be skipped for current scan period.
我在容器使用 hciconfig 是能发现 hci0 是 running 的
使用是正常的,就是偶尔传感器的数据读不了。。
对于温湿度是没多大影响,但对于门窗传感器就影响大了,一次没更新自动化都触发不了了。。
帖子
1508
 楼主| 发表于 2022-5-21 15:12:00 | 显示全部楼层
看到了一周前才加的新功能, 已更新.
帖子
1508
 楼主| 发表于 2022-5-21 15:17:19 | 显示全部楼层
HCIdump thread: Something wrong - inte ...
没有出现过这个问题, 看看是docker的问题,还是蓝牙适配器硬件的瓶颈: 无法持续扫描
ESP32就存在这样的硬件的瓶颈,因为它与WIFI是共用通道,所以只能分时间片处理.可以调校scan_parameters,但是如果蓝牙占用太多的时间,那么WIFI就会出问题.
最好的办法是ESP32只开蓝牙,另外加ESP8266芯片单独处理WIFI
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-6-2 21:58 , Processed in 3.298292 second(s), 30 queries .
Powered by Discuz! X3.4
