『瀚思彼岸』» 智能家居技术论坛
楼主: zjhcr
[基础教程] 汉非太阳能(光伏)控制器接入ha小白级教程
帖子
1406
Rank: 6Rank: 6
发表于 2021-12-21 11:15:47 | 显示全部楼层
用锂电池?感觉怕怕的
帖子
820
Rank: 4
 楼主| 发表于 2021-12-21 11:43:21 | 显示全部楼层
ztrx 发表于 2021-12-21 11:15
用锂电池?感觉怕怕的
目前我还是在用淘汰下来修复的铅酸电瓶
但还是建议一步到位上锂电,锂电不会像铅酸吃得多放得少。
三元锂危险点,用磷酸铁锂还是挺安全的呀
帖子
1899
Rank: 6Rank: 6
发表于 2021-12-21 14:45:17 | 显示全部楼层
看一下。不错的话我在家里也搞一个这样的。
帖子
2181
Rank: 6Rank: 6
发表于 2021-12-21 16:35:48 | 显示全部楼层
我擦,这个市政让随便接吗?得放楼顶上吧?要不光照只有挺短时间的吧?然后拉根线下来接入电表?那还得弄两路电?太高端。。。。。没琢磨明白。
帖子
820
Rank: 4
 楼主| 发表于 2021-12-21 16:40:34 来自手机 | 显示全部楼层
telanx 发表于 2021-12-21 16:35
我擦,这个市政让随便接吗?得放楼顶上吧?要不光照只有挺短时间的吧?然后拉根线下来接入电表?那还得弄两 ...
你说的那是并网,离网是不接入市电,不需要任何批准手续的,有地方放光伏板就行。是的,楼顶光照最好,没有遮挡最合适
帖子
820
Rank: 4
 楼主| 发表于 2021-12-21 21:01:45 | 显示全部楼层
接1楼继续
modbus:
  - type: tcp
    close_comm_on_error: false
#host、port改成你控制器的IP和端口
    host: 192.168.1.86
    port: 8088
    sensors:
      - name: PV_Voltage
        slave: 1
        address: 1
        input_type: holding
        unit_of_measurement: V
        scale: 0.01
        precision: 2
        device_class: voltage
        scan_interval: 5
      - name: PV_Current
        slave: 1
        address: 2
        input_type: holding
        unit_of_measurement: A
        scale: 0.01
        precision: 2
        device_class: current
        scan_interval: 5
      - name: PV_Power
        slave: 1
        address: 3
        unit_of_measurement: W
        device_class: power
        input_type: holding
        scan_interval: 5
      - name: PV_State
        slave: 1
        address: 4
        input_type: holding
        scan_interval: 5
      - name: Battery_Voltage
        slave: 1
        address: 5
        scale: 0.01
        precision: 2
        device_class: battery
        input_type: holding
        scan_interval: 5
      - name: Battery_Temperature
        slave: 1
        address: 6
        unit_of_measurement: °C
        device_class: temperature
        input_type: holding
        scan_interval: 5
      - name: Charge_Current
        slave: 1
        address: 7
        scale: 0.01
        precision: 2
        input_type: holding
        scan_interval: 5
      - name: Discharge_Current
        slave: 1
        address: 8
        scale: 0.01
        precision: 2
        input_type: holding
        scan_interval: 5
      - name: Battery_Level
        slave: 1
        address: 10
        unit_of_measurement: "%"
        input_type: holding
        scan_interval: 5
      - name: Charge_State
        slave: 1
        address: 11
        input_type: holding
        scan_interval: 5
      - name: Controller_Temperature
        slave: 1
        address: 12
        input_type: holding
        scan_interval: 5
      - name: Controller_TotalEnergy
        slave: 1
        address: 16
        unit_of_measurement: kAh
        device_class: energy
        input_type: holding
        scan_interval: 5
      - name: Controller_TotalUsed
        slave: 1
        address: 20
        unit_of_measurement: Ah
        input_type: holding
        scan_interval: 5
  - platform: template
    sensors:
      pv_state_change:
        friendly_name: '光伏板状态'
        value_template: >
          {% if is_state('sensor.pv_state', '0') %}
            低电压未发电
          {% elif is_state('sensor.pv_state', '1') %}
            发电中
          {% elif is_state('sensor.pv_state', '2') %}
            过压保护
          {% elif is_state('sensor.pv_state', '3') %}
            光伏板未接入
          {% endif %}
      pv_voltage_change:
        friendly_name: '光伏板电压'
        value_template: >
          {% set state = states('sensor.pv_voltage') %}{{ (state) }}
      pv_current_change:
        friendly_name: '光伏板电流'
        value_template: >
          {% set state = states('sensor.pv_current') %}{{ (state) }}
      pv_power_change:
        device_class: power
        friendly_name: '光伏功率'
        value_template: >
          {% set state = states('sensor.pv_power_change2') %}{{ (state) }}
      battery_voltage_change:
        friendly_name: '蓄电池电压'
        value_template: >
          {% set state = states('sensor.battery_voltage') %}{{ (state) }}
      discharge_current_change:
        friendly_name: '放电电流'
        value_template: >
          {% set state = states('sensor.discharge_current') %}{{ (state) }}
      discharge_power_change:
        device_class: power
        friendly_name: '放电功率'
        value_template: >
          {% set state = states('sensor.discharge_power_change2') %}{{ (state) }}
      controller_temperature_change:
        friendly_name: '控制器温度'
        value_template: >
          {% set state = states('sensor.controller_temperature') %}{{ (state) }}
      battery_temperature_change:
        friendly_name: '蓄电池温度'
        value_template: >
          {% set state = states('sensor.battery_temperature') %}{{ (state) }}
      battery_level_change:
        friendly_name: '蓄电池电量'
        value_template: >
          {% set state = states('sensor.battery_level') %}{{ (state) }}
      charge_state_change:
        friendly_name: '充电模式'
        value_template: >
            停充
            强充
            MPPT
            浮充
          {% elif is_state('sensor.pv_state', '4') %}
            提升
          {% elif is_state('sensor.pv_state', '5') %}
            均衡
          {% elif is_state('sensor.pv_state', '6') %}
            恒流
          {% elif is_state('sensor.pv_state', '7') %}
            恒压
          {% endif %}
      controller_totalenergy_change:
        unit_of_measurement: kWh
        friendly_name: '总发电量'
        value_template: >
          {% set state = states('sensor.controller_totalenergy') %}{{ (state | float * 0.12 ) | round(2)}}
      controller_totalused_change:
        friendly_name: '总用电量'
        value_template: >
          {% set state = states('sensor.controller_totalused') %}{{ (state | float * 0.012 ) | round(2)}}
template:
  - sensor:
      - name: "PV Power Change2"
        state: "{{ (states('sensor.battery_voltage')|float * states('sensor.pv_current')|float ) | round(2) }}"
        device_class: power
      - name: "Discharge Power Change2"
        state: "{{ (states('sensor.battery_voltage')|float * states('sensor.Discharge_Current')|float ) | round(2) }}"
        device_class: power
如果只想白嫖代码的话,到这里直接复制粘贴就已经基本完成了,如果想学习代码的内容那么可以接着往下看
首先modbus: 调用HA的Modbus协议支持host: 和 port: 需要改成你自己控制器接入了内网的地址和端口
sensors: 部分就是HA的通过获取到的Modbus数据转换成传感器参数,这里举一个例子:
    sensors:
      - name: PV_Voltage  #在HA里生成的实体名称,这里取PV_Voltage意为光伏板电压
        slave: 1     #从位数,Modbus作用于TCP模式时可不填,我统一填1
        address: 1   #地址,这个就是前面我提到协议里的地址,1代表0x0001,读取地址1的数据
        input_type: holding #输入类型,对应的是ModScan32里的03:Holding Register,一般读数都选择该类型
        unit_of_measurement: V #测量单位,V代表是电压,根据所读的数属于哪种单位来填写,例如电流是A
        scale: 0.01     #通过Modbus读取过来的光伏电压数值是1267,实际是12.67,需用使用该参数转换增加小数点
        precision: 2    #保留小数点后2位精度
        device_class: voltage   #设备种类,这个属于电压,具体有哪些设备种类可参照HA官方文档
        scan_interval: 5    #扫描间隔,就是每隔多久更新一次数据,单位是秒
如此类推把所有对应的地址和协议中的数值都可以读取成为HA里的实体……
由于原厂读取的光伏功率和放电功率都是没有数值(厂家bug?),所以我又建了两个模板sensor用公式自己拿电压和电流乘积得出两个功率的实体,又另外把发电量和用电量原本是Ah安时的单位转换成了kWh千瓦时,但发现模板sensor无法增加state_class: total_increasing 参数,致使发电量数据暂时还没有办法接入HA的能源板块,这个问题有待解决
添加好代码内容后保存mppt.yaml
然后重启HA
可以在实体注册表里看到了很多新生成的实体
剩下的事情,就是拿这些实体在Lovelace,也就是HA的主界面,新建你喜欢的卡片类型来展示,就可以了。
注意要选取中文名称的那些实体哈哈
对了,如果经常出现“实体不可用”的显示,则要考虑是否存在控制器与WiFi连接的信号强度不佳,ESP-12F内置芯片信号没那么强
ModScan32、汉非控制器的协议文件、MPPT.yaml这几样都在附件里了
上位机软件和NotePad++都超过了3M的附件限制,无法发附件里了
最后还请路过的大佬们帮忙解决一下模板sensor无法增加state_class: total_increasing 参数,致使发电量、用电量这两实体的数据暂时还没有办法接入HA的能源板块这个问题,万分感谢~
ModScan32.zip
2.15 MB, 下载次数: 14
控制器通信协议(ModBus版)公开文件V1.0.0_CN.pdf
327.16 KB, 下载次数: 11
mppt.yaml.rar
1.21 KB, 下载次数: 16
帖子
1133
Rank: 6Rank: 6
发表于 2021-12-21 21:34:08 | 显示全部楼层
楼主你怎么应用的?是接了逆变器还是ups
帖子
1133
Rank: 6Rank: 6
发表于 2021-12-21 21:40:37 | 显示全部楼层
如果搞明白了协议,其实可以直接刷esp12f,刷成esphome固件,可以直接接入ha
帖子
820
Rank: 4
 楼主| 发表于 2021-12-21 21:54:37 | 显示全部楼层
我玩的光伏功率不大,电池也不大,基本都是直流负载,有摄像头、有路由器有网桥、有工控机,到了夏天光照好的时候,带个逆变器来带带风扇吹吹风,哈哈
帖子
820
Rank: 4
 楼主| 发表于 2021-12-21 22:01:46 | 显示全部楼层
一开始的思路我也是这么想的,后来发现这个内置的12F原厂esp-link固件剩余空间太小,无法直接通过无线OTA刷入新固件,要拆机飞线刷,比较麻烦,我的设备都已经全部接好电线固定上机柜。其次是这个控制器它用的是Modbus标准协议,后来刚好看到HA能够直接支持Modbus TCP通讯,干脆直接用HA读取Modbus,12F继续用esp-link充当透传,反而还更省事了~
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-6-2 20:14 , Processed in 0.059565 second(s), 32 queries .
Powered by Discuz! X3.4
