『瀚思彼岸』» 智能家居技术论坛
查看: 1924|回复: 3
[教程系列] node-RED安装后有一个警告,不知是什么意思
帖子
236
Rank: 3Rank: 3
发表于 2021-9-6 22:13:06 | 显示全部楼层 |阅读模式
我是用猫盘上的portainer装的,装好后进入有这样一个警告。
Node
"3cc11d24.ff01a2"
Type comment
Unfold
WARNING: please check you have started this container with a volume that is mounted to /data\n otherwise any flow changes are lost when you redeploy or upgrade the container\n (eg upgrade to a more recent node-red docker image).\ n If you are using named volumes you can ignore this warning.\n Double click or see info side panel to learn how to start Node-RED in Docker to save your work
To start docker with a bind mount volume (-v option), for example:
docker run -it -p 1880:1880 -v /home/user/node_red_data:/data --name mynodered nodered/node-red
where /home/user/node_red_data is a directory on your host machine where you want to store your flows.
If you do not do this then you can experiment and redploy flows, but if you restart or upgrade the container the flows will be disconnected and lost.
They will still exist in a hidden data volume, which can be recovered using standard docker techniques, but that is much more complex than just starting with a named volume as described above.
帖子
2186
发表于 2021-9-6 22:57:41 | 显示全部楼层
没映射出去,建议看看docker基础知识
帖子
236
Rank: 3Rank: 3
 楼主| 发表于 2021-9-7 09:36:34 | 显示全部楼层
感谢回复,我就是搞不懂v node_red_data:/data 在portainer中卷是怎么设的。
帖子
236
Rank: 3Rank: 3
 楼主| 发表于 2021-9-7 11:18:38 | 显示全部楼层
已解决,我用WinSCP在dcoker目录中建了个node_red_data目录,然后主机填创建的目录地址后不报错了
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-6-3 08:26 , Processed in 0.109994 second(s), 28 queries .
Powered by Discuz! X3.4
