- 积分
- 845
- 金钱
- 762
- 威望
- 0
- 贡献
- 0
- HASS币
- 0
- 积分
- 845
- 金钱
- 762
- HASS币
- 0
发表于 2021-1-22 21:17:13
显示全部楼层
请问小沐智能马桶盖,可以支持么,这是命令结果
INFO:miio.cliebug mode active
Running command raw_command
DEBUG:miio.protocol:Unable to decrypt, returning raw bytes: b''
DEBUG:miio.miioprotocol:Got a response: Container:
data = Container:
data = b'' (total 0)
value = b'' (total 0)
offset1 = 32
offset2 = 32
length = 0
header = Container:
data = b'!1\x00 \x00\x00\x00\x00\x05.(q\x00t\x1be' (total 16)
value = Container:
length = 32
unknown = 0
device_id = b'\x05.(q' (total 4)
ts = 1970-03-30 01:39:49
offset1 = 0
offset2 = 16
length = 16
checksum = b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00' (total 16)
DEBUG:miio.miioprotocoliscovered 052e2871 with ts: 1970-03-30 01:39:49, token: b'00000000000000000000000000000000'
DEBUG:miio.miioprotocol:192.168.1.110:54321 >>: {'id': 1, 'method': 'get_properties', 'params': [{'did': 'result', 'siid': 2, 'piid': 1}]}
DEBUG:miio.miioprotocol:192.168.1.110:54321 (ts: 1970-03-30 01:39:50, id: 1) << {'error': {'code': -9999, 'message': 'UART timeout'}, 'id': 1}
DEBUG:miio.click_common:Exception: {'code': -9999, 'message': 'UART timeout'}
File "/usr/local/lib/python3.8/site-packages/miio/click_common.py", line 59, in __call__
return self.main(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/click/core.py", line 782, in main
rv = self.invoke(ctx)
File "/usr/local/lib/python3.8/site-packages/click/core.py", line 1259, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/usr/local/lib/python3.8/site-packages/click/core.py", line 1066, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/usr/local/lib/python3.8/site-packages/click/core.py", line 610, in invoke
return callback(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/miio/click_common.py", line 280, in wrap
kwargs["result"] = func(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/click/decorators.py", line 73, in new_func
return ctx.invoke(f, obj, *args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/miio/click_common.py", line 245, in command_callback
return miio_command.call(miio_device, *args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/miio/click_common.py", line 193, in call
return method(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/miio/device.py", line 162, in raw_command
return self.send(command, parameters)
File "/usr/local/lib/python3.8/site-packages/miio/device.py", line 143, in send
return self._protocol.send(
File "/usr/local/lib/python3.8/site-packages/miio/miioprotocol.py", line 213, in send
self._handle_error(payload["error"])
File "/usr/local/lib/python3.8/site-packages/miio/miioprotocol.py", line 273, in _handle_error
raise DeviceError(error)
miio.exceptions.DeviceError: {'code': -9999, 'message': 'UART timeout'}
Error: {'code': -9999, 'message': 'UART timeout'} |
