『瀚思彼岸』» 智能家居技术论坛
楼主: 27hh
[修仙教程] 【持续更新优化】小米米家智能设备通用接入HomeAssistant插件
帖子
4233
Rank: 8Rank: 8
教程狂人论坛风云人物
 楼主| 发表于 2020-12-31 12:58:00 | 显示全部楼层
itispip 发表于 2020-12-31 00:42
不要买了。米家的重点明显转到蓝牙Mesh上面去了,以后的蓝牙设备估计都是Mesh的。 ...
并不是的,目前看来只有需要操控的设备(开关,灯泡等)才用mesh网关,其他只读的设备如传感器,温湿度计,都是只需要普通蓝牙网关
帖子
4233
Rank: 8Rank: 8
教程狂人论坛风云人物
 楼主| 发表于 2020-12-31 12:59:02 | 显示全部楼层
MattSmell 发表于 2020-12-30 21:04
插座是“米家智能插座2 蓝牙网关版”吗,正准备买一个
是这个插座,但是接入了HA蓝牙设备的信息也是读不到的
帖子
4180
Rank: 8Rank: 8
发表于 2020-12-31 16:15:29 | 显示全部楼层
发现家里的鹿客猫眼也是miot协议,但是发现数据格式有点不一样,有一个enents字段,不知道是不是插件现在不支持这种类型
    "type":"urn:miot-spec-v2:device:video-doorbell:0000A03A:loock-v01:1",
    "description":"Video Doorbell",
    "services":[
            "iid":1,
            "type":"urn:miot-spec-v2:service:device-information:00007801:loock-v01:1",
            "description":"Device Information",
            "properties":[
                    "iid":1,
                    "type":"urn:miot-spec-v2:property:manufacturer:00000001:loock-v01:1",
                    "description":"Device Manufacturer",
                    "format":"string",
                    "access":[
                        "read"
                    "iid":2,
                    "type":"urn:miot-spec-v2:property:model:00000002:loock-v01:1",
                    "description":"Device Model",
                    "format":"string",
                    "access":[
                        "read"
                    "iid":3,
                    "type":"urn:miot-spec-v2:property:serial-number:00000003:loock-v01:1",
                    "description":"Device Serial Number",
                    "format":"string",
                    "access":[
                        "read"
                    "iid":4,
                    "type":"urn:miot-spec-v2:property:firmware-revision:00000005:loock-v01:1",
                    "description":"Current Firmware Version",
                    "format":"string",
                    "access":[
                        "read"
            "iid":2,
            "type":"urn:miot-spec-v2:service:video-doorbell:00007863:loock-v01:1",
            "properties":[
                    "iid":1,
                    "type":"urn:miot-spec-v2:property:current-time:00000098:loock-v01:1",
                    "description":"Current Time",
                    "format":"string",
                    "access":[
            "events":[
                    "iid":1,
                    "type":"urn:miot-spec-v2:event:doorbell-ring:00005013:loock-v01:1",
                    "description":"Doorbell Ring",
                    "arguments":[
帖子
904
Rank: 4
发表于 2020-12-31 16:23:37 | 显示全部楼层
提个反馈:当通过HACS来安装这个Github Resposit的时候,这个组件会直接代替MIIO,而并不是出现在custom components目录下啊。希望能支持HACS安装以方便更新。。。
帖子
3072
Rank: 8Rank: 8
发表于 2020-12-31 17:44:17 | 显示全部楼层
itispip 发表于 2020-12-31 16:23
提个反馈:当通过HACS来安装这个Github Resposit的时候,这个组件会直接代替MIIO,而并不是出现在custom co ...
樓主有寫到 因為他是 Flok Syssi 大神的 Resposit 後修改的
有需求的人 或許也可以幫忙編寫一下就是(我是只能幫忙翻譯 哈)
帖子
4233
Rank: 8Rank: 8
教程狂人论坛风云人物
 楼主| 发表于 2020-12-31 19:26:29 | 显示全部楼层
感谢反馈,是我忘了修改manifest了。现在应该没有问题了
帖子
1547
发表于 2020-12-31 21:31:40 | 显示全部楼层
你好,我照搬了功率代码,显示出来还是没有小数点的百倍数值。
帖子
803
发表于 2021-1-1 07:51:05 | 显示全部楼层
楼主的精彩贴,解决我的困扰,真的学到了不少东西。
帖子
786
Rank: 4
发表于 2021-1-1 09:12:17 | 显示全部楼层
网关怎么接入呀。。。
帖子
1168
Rank: 6Rank: 6
发表于 2021-1-1 18:29:02 来自手机 | 显示全部楼层
谢谢大佬,成功接入gosund,实现高性价比
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-6-2 13:09 , Processed in 0.072297 second(s), 31 queries .
Powered by Discuz! X3.4
