楼主: mac_zhou
[插件集成] 美的空调-局域网协议控制[新协议已支持]
发表于 2022-7-4 22:14:07 | 显示全部楼层
美的热水器,运行信息如下,有点价值吗?
C:\Users\Administrator.USER-20171001VJ> midea-discover
INFO:msmart.cli:msmart version: 0.2.3 Currently only supports ac devices, only support MSmartHome APP.
ERROR:msmart.security:authentication failed
ERROR:msmart.lan:Authentication failed for 192.168.88.254:52140 -> 192.168.88.252:6444 retries: 0 time: 0.04
INFO:msmart.lan:Got TCP key for 192.168.88.254:52140 -> 192.168.88.252:6444 retries: 0 time: 1.26 tcp_key: 8c4e1ab8f639654168ff5096607ccc5d1f22e1062137eeb524545963dd415043
INFO:msmart.cli:*** Found a device: {'name': 'midea_e3_0100', 'ssid': 'midea_e3_0100', 'ip': '192.168.88.252', 'port': 6444, 'id': 185817465495782, 'version': 3, 'token': 'C2B990B709436F1BD3FC7285688C4DD05C1250ECB5032AD18D1C1B7A80A379E07A2543BF0DD3E8FD9B38C44015AC52722023E9290E79603847C1A548470EEC91', 'key':'DEF4B162B22B4CAB8466797D07B1E4B6ACAA49EDD755465EB814F1886334F8A8', 'type': 'e3',
'sn': '0E3211511017341B0614001002PJW', 'model': '01734', 'support': False, 'run_test': True}
但发现每次获取的token和key都不一样。
发表于 2022-8-28 22:41:21 | 显示全部楼层
已经安装,好用的很,谢谢大佬分享!!
发表于 2022-11-12 22:42:30 | 显示全部楼层
V3的空调可以添加   但无法控制
发表于 2022-12-16 21:11:55 | 显示全部楼层
这个报错,改了下cli.py,不起作用的
root@raspberrypi:/home/anglee# midea-discover
INFO:msmart.cliiscovering devices with UDP Broadcast, press CTRL-C to quit...
ERROR:msmart.security:aes_decrypt error: ValueError('Padding is incorrect.') - data: 000001800000000063e616534d715753441953830689743757d6b1516f0c4031c7fbfc2a1d0f12534258dfeb43ce3ffddb03727e0dcda80779682dae181425ac
  File "/usr/local/bin/midea-discover", line 8, in <module>
    sys.exit(discover())
  File "/usr/lib/python3/dist-packages/click/core.py", line 829, in __call__
    return self.main(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/click/core.py", line 782, in main
    rv = self.invoke(ctx)
  File "/usr/lib/python3/dist-packages/click/core.py", line 1066, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/usr/lib/python3/dist-packages/click/core.py", line 610, in invoke
    return callback(*args, **kwargs)
  File "/usr/local/lib/python3.9/dist-packages/msmart/cli.py", line 67, in discover
    m_type = m_ssid.split('_')[1]
IndexError: list index out of range
发表于 2023-6-6 13:36:51 | 显示全部楼层
大佬你好,这个协议哪里可以下载呢。我要将加热净水器加入HA,没有协议。
发表于 2023-6-14 16:34:43 | 显示全部楼层
发表于 2023-11-9 16:09:53 | 显示全部楼层
老哥用了你的插件几台新空调都接入了,但是有一台colom的带线控的接不进!
发表于 2025-6-17 11:09:19 | 显示全部楼层
请问现在还能用吗
GMT+8, 2025-9-19 07:03 , Processed in 1.283952 second(s), 12 queries , MemCached On.
