楼主: 27hh
[进阶教程] 闲置安卓手机安装HA变身智能家居中枢,及网关接入教程
27hh
教程狂人论坛风云人物
 楼主| 发表于 2017-9-6 21:19:53 | 显示全部楼层
star_liu 发表于 2017-9-6 18:02
感谢大神耐心的解答,开启BR的时候提示这个问题,不知道修改哪里
上面那个红字没有影响,下面直接翻译就是无法连接。我怎么觉得截图不全呢?
发表于 2017-9-6 21:53:51 | 显示全部楼层
27hh 发表于 2017-9-6 21:19
上面那个红字没有影响,下面直接翻译就是无法连接。我怎么觉得截图不全呢? ...
完整的是这个。。。HASS现在很正常了
*** WARNING *** The program 'nodejs' uses the Apple Bonjour compatibility layer        of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libd        ns_sd&e=nodejs>
*** WARNING *** The program 'nodejs' called 'DNSServiceRegister()' which is not        supported (or only supported partially) in the Apple Bonjour compatibility layer        of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libd        ns_sd&e=nodejs&f=DNSServiceRegister>
[9/6/2017, 8:58:20 PM] Loaded plugin: homebridge-homeassistant
[9/6/2017, 8:58:20 PM] Registering platform 'homebridge-homeassistant.HomeAssist        ant'
[9/6/2017, 8:58:20 PM] ---
[9/6/2017, 8:58:20 PM] Loaded config.json with 0 accessories and 1 platforms.
[9/6/2017, 8:58:20 PM] Loading 1 platforms...
[9/6/2017, 8:58:20 PM] [HomeAssistant] Initializing HomeAssistant platform...
[9/6/2017, 8:58:20 PM] [HomeAssistant] Please set default_visibility in config.j        son to "hidden" or "visible".
[9/6/2017, 8:58:20 PM] [HomeAssistant] Fetching HomeAssistant devices.
events.js:163
      throw er; // Unhandled 'error' event
Error: connect EACCES 192.168.0.236:8123 - Local (undefined:undefined)
    at Object.exports._errnoException (util.js:1050:11)
    at exports._exceptionWithHostPort (util.js:1073:20)
    at internalConnect (net.js:889:16)
    at lookupAndConnect (net.js:977:5)
    at Socket.realConnect (net.js:945:5)
    at Agent.connect [as createConnection] (net.js:77:22)
    at Agent.createSocket (_http_agent.js:195:26)
    at Agent.addRequest (_http_agent.js:157:10)
    at new ClientRequest (_http_client.js:212:16)
    at Object.request (http.js:26:10)
发表于 2017-9-7 10:40:29 | 显示全部楼层
(这里提供一个我写的脚本,执行此脚本后可以省去一部分复制粘贴的麻烦,可以空降到“创建 Python 虚拟运行环境并切换”步骤继续。)   1.sh.zip (411 Bytes, 下载次数: 20)   这个怎么操作??如何执行脚本?小白一枚请见谅
发表于 2017-9-7 13:05:24 | 显示全部楼层
你好  帮我看下这是什么情况
发表于 2017-9-7 16:47:57 | 显示全部楼层
启动自动运行可以参考论坛的另一个帖子,好像hass-daemon这个文件有点问题
发表于 2017-9-8 10:33:14 | 显示全部楼层
哪一个帖子?
发表于 2017-9-8 11:09:29 | 显示全部楼层
27hh
教程狂人论坛风云人物
 楼主| 发表于 2017-9-8 11:27:26 | 显示全部楼层
zzx386 发表于 2017-9-7 10:40
(这里提供一个我写的脚本,执行此脚本后可以省去一部分复制粘贴的麻烦,可以空降到“创建 Python 虚拟运行 ...
用ftp把这个文件传到某个目录比如/home/android/,然后chmod 777 1.sh,最后sh 1.sh
发表于 2017-9-8 13:11:33 | 显示全部楼层
你好 ftp这个软件有问题?
发表于 2017-9-8 16:49:30 | 显示全部楼层
不折腾了 小白折腾不起 可惜了
GMT+8, 2025-9-14 02:56 , Processed in 0.191873 second(s), 17 queries , MemCached On.
