查看: 3326|回复: 0
[智能音箱] 小爱音响,请问大神这是什么故障,有解吗?(UBIFS error))
发表于 2020-3-30 23:02:08 | 显示全部楼层 |阅读模式
绿板小爱音响顶部红灯一直转圈,请问大神这是什么故障,有解吗?(UBIFS error)V信:15389888073
TTL跑码如下:
AXG:BL1:d95c53:a4926f;FEAT:E0DC318C:2000OC:F;EMMC:800;NAND:0;READ:0;0.0;CHK:0;
sdio debug board detected
TE: 23353
BL2 Built : 18:30:39, Aug 28 2018. axg g56303a2-dirty - liang.yang@droid11-sz
set vcck to 1140 mv
set vddee to 1070 mv
Board ID = 2
CPU clk: 1200MHz
DDR low power enabled
DDR3 chl: Rank0 16bit @ 792MHz
bist_test rank: 0 30 09 57 35 12 59 2a 04 51 38 15 5b 00 00 00 00 00 00 00 00 00 00 00 00 612   - PASS
Rank0: 256MB(auto)-2T-11
AddrBus test pass!
NAND init
page0 page0->bbt:
0000000000000000000000000000000000000000000000000000000000000000
page0 bbt:
Load FIP HDR from NAND, src: 0x0000c000, des: 0x01700000, size: 0x00004000
Load BL3x from NAND, src: 0x00010000, des: 0x01704000, size: 0x00080000
NOTICE:  BL31: v1.3(release):a1a8551
NOTICE:  BL31: Built : 15:59:55, Nov  9 2017
NOTICE:  BL31: AXG normal boot!
NOTICE:  BL31: BL33 decompress pass
[Image: axg_v1.1.3268-b93dd79 2017-12-01 14:22:18 huan.biao@droid12]
OPS=0x42
f 8f cf 31 d2 21 45 b6 b 57 12 72 bl30:axg ver: 9 mode: 0
bl30:axg thermal0
[0.014439 Inits done]
secure task start!
high task start!
low task start!
ERROR:   Error initializing runtime service opteed_fast
U-Boot 2015.01 (Dec 11 2018 - 23:50:47), Build: jenkins-Mico_s12a_ota_publish-299
DRAM:  256 MiB
Relocation Offset is: 0ef17000
register usb cfg[0][1] = 000000000ff89590
NAND:  nand id: 0x98 0xda
256MiB, SLC, page size: 2048, OOB size: 64
NAND device id: 98 da 90 15 f6 16
NAND device: Manufacturer ID: 0x98, Chip ID: 0x98 (Toshiba A revision NAND 2Gib TC58BVG1S3HTA00 )
oob avail size 6
Creating 1 MTD partitions on "A revision NAND 2Gib TC58BVG1S3HTA00 ":
0x000000000000-0x000000200000 : "bootloader"
A revision NAND 2Gib TC58BVG1S3HTA00  initialized ok
nand id: 0x98 0xda
PLANE change!
aml_nand_init obmul=1,oobfree.length=8,oob_size=64
oob avail size 8
bbt_start=20 env_start=24 key_start=32 dtb_start=40
nbbt: info size=0x800 max_scan_blk=24, start_blk=20
nbbt : phy_blk_addr=20, ec=0, phy_page_addr=0, timestamp=1
nbbt free list:
blockN=21, ec=-1, dirty_flag=0
blockN=22, ec=-1, dirty_flag=0
blockN=23, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=1
aml_nand_scan_rsv_info 1254
nbbt valid addr: 280000
aml_nand_bbt_check 1389 bbt is valid, reading.
aml_nand_read_rsv_info:397,read nbbt info to 280000
nenv: info size=0x10000 max_scan_blk=32, start_blk=24
nenv : phy_blk_addr=24, ec=48, phy_page_addr=0, timestamp=97
nenv free list:
blockN=25, ec=47, dirty_flag=1
blockN=26, ec=-1, dirty_flag=0
blockN=27, ec=-1, dirty_flag=0
blockN=28, ec=-1, dirty_flag=0
blockN=29, ec=-1, dirty_flag=0
blockN=30, ec=-1, dirty_flag=0
blockN=31, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=32
nenv valid addr: 310000
nkey: info size=0x8000 max_scan_blk=40, start_blk=32
nkey : phy_blk_addr=33, ec=0, phy_page_addr=0, timestamp=2
nkey free list:
blockN=32, ec=0, dirty_flag=1
blockN=34, ec=-1, dirty_flag=0
blockN=35, ec=-1, dirty_flag=0
blockN=36, ec=-1, dirty_flag=0
blockN=37, ec=-1, dirty_flag=0
blockN=38, ec=-1, dirty_flag=0
blockN=39, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=16
nkey valid addr: 420000
ndtb: info size=0x20000 max_scan_blk=44, start_blk=40
ndtb : phy_blk_addr=41, ec=2, phy_page_addr=0, timestamp=6
ndtb free list:
blockN=40, ec=2, dirty_flag=1
blockN=42, ec=-1, dirty_flag=0
blockN=43, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=64
ndtb valid addr: 520000
tpl: off 8388608, size 8388608
NAND bbt detect factory Bad block at 7100000
NAND bbt detect factory Bad block at c000000
NAND bbt detect factory Bad block at c020000
Creating 6 MTD partitions on "A revision NAND 2Gib TC58BVG1S3HTA00 ":
0x000000800000-0x000001000000 : "tpl"
0x000001000000-0x000001800000 : "boot0"
0x000001800000-0x000002000000 : "boot1"
0x000002000000-0x000004000000 : "system0"
0x000004000000-0x000006000000 : "system1"
0x000006000000-0x000010000000 : "data"
aml_key_init 170
MMC:
uboot env amlnf_env_read : ####
aml_nand_read_rsv_info:397,read nenv info to 310000
In:    serial
Out:   serial
Err:   serial
[store]To run cmd[amlnf dtb_read 0x1000000 0x20000]
sub cmd dtb
new argv[1] dtb_read
do_dtb_ops(): argc 4
arg 0: amlnf
arg 1: dtb_read
arg 2: 0x1000000
arg 3: 0x20000
do_dtb_ops() read
amlnf_dtb_read: ####
aml_nand_read_rsv_info:397,read ndtb info to 520000
do_dtb_ops(): 131072 bytes read : OK
      Amlogic multi-dtb tool
      GZIP format, decompress...
      Multi dtb detected
      Multi dtb tool version: v2 .
      Support 5 dtbs.
        aml_dt soc: xiaomi platform: s12a variant: v01
        dtb 0 soc: xiaomi   plat: s12   vari: v1
        dtb 1 soc: xiaomi   plat: s12a   vari: v01
        dtb 2 soc: xiaomi   plat: s12c   vari: v01
        dtb 3 soc: xiaomi   plat: s12c   vari: v02
        dtb 4 soc: xiaomi   plat: s12c   vari: v03
      Find match dtb: 1
amlkey_init() enter!
amlnf_key_read key data len too much
aml_nand_read_rsv_info:397,read nkey info to 420000
[EFUSE_MSG]keynum is 4
InUsbBurn
noSof
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
HAVE SN Code ...
Saving Environment to aml-storage...
uboot env amlnf_env_save : ####
aml_nand_save_rsv_info:656, nenv: valid=1, pages=32
release_free_node 61: bitmap=1fffff
release_free_node 74: bitmap=1ffff7
aml_nand_save_rsv_info:716,save info to 320000
aml_nand_write_rsv:520,write info to 320000
[burnup]Rd:Up sz 0x3a6440 to align 0x1000
save_power_post ...
## Booting Android Image at 0x01080000 ...
reloc_addr =f0348e0
copy done
load dtb from 0x1000000 ......
      Single dtb detected
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x01080000, end = 0x017a7808
   Loading Ramdisk to 0eead000, end 0f004974 ... OK
   Loading Device Tree to 000000000eea2000, end 000000000eeac807 ... OK
Starting kernel ...
uboot time: 1826120 us
domain-0 init dvfs: 4
[    0.284762@2] ff803000.serial: clock gate not found
get key is 0x00 , curr_boot is boot1
Booting from boot1
/dev/mtdblock5 is ready now.
[    0.737631@2] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[    0.737754@2] i2c i2c-1: token 1, master_no(1) 300K addr 0x3c
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
Please press Enter to activate this console.
[    5.874059@0] cyttsp 0-0008: Failed to request firmware touch.cyacd
[    5.874689@0] cyttsp 0-0008: Failed to update firmware;
[    7.761410@1] UBIFS error (ubi0:0 pid 950): ubifs_scan: bad node
[    7.770703@1] UBIFS error (ubi0:0 pid 950): ubifs_recover_leb: corruption -3
[    7.772115@1] UBIFS error (ubi0:0 pid 950): ubifs_check_node: bad node length 64
[    7.779457@1] UBIFS error (ubi0:0 pid 950): ubifs_check_node: bad node at LEB 4:2048
[    7.787122@1]        magic          0x6101831
[    7.790918@1]        crc            0x34d923b6
[    7.794795@1]        node_type      0 (inode node)
[    7.799022@1]        group_type     0 (no node group)
[    7.803506@1]        sqnum          902817
[    7.807040@1]        len            64
[    7.810245@1]        key            (0, inode)
[    7.814117@1]        creat_sqnum    1897141343029821440
[    7.818771@1]        size           0
[    7.821877@1]        nlink          0
[    7.824974@1]        atime          -2702734863953297408.28
[    7.829984@1]        mtime          0.1956
[    7.833521@1]        ctime          8547360110304827441.5
[    7.838350@1]        uid            0
[    7.841456@1]        gid            0
[    7.844552@1]        mode           0
[    7.847665@1]        flags          0x0
[    7.850942@1]        xattr_cnt      0
[    7.854047@1]        xattr_size     0
[    7.857145@1]        xattr_names    0
[    7.860256@1]        compr_type     0x0
[    7.863535@1]        data len       0
[    7.866850@3] UBIFS error (ubi0:0 pid 950): ubifs_scanned_corruption: corruption at LEB 4:2048
[    7.875231@3] UBIFS error (ubi0:0 pid 950): ubifs_scanned_corruption: first 8192 bytes from LEB 4:2048
[    7.886784@3] UBIFS error (ubi0:0 pid 950): ubifs_recover_leb: LEB 4 scanning failed
[    8.505073@3] UBIFS error (ubi0:0 pid 963): ubifs_scan: bad node
[    8.514358@3] UBIFS error (ubi0:0 pid 963): ubifs_recover_leb: corruption -3
[    8.515760@3] UBIFS error (ubi0:0 pid 963): ubifs_check_node: bad node length 64
[    8.523098@3] UBIFS error (ubi0:0 pid 963): ubifs_check_node: bad node at LEB 4:2048
[    8.530774@3]        magic          0x6101831
[    8.534561@3]        crc            0x34d923b6
[    8.538446@3]        node_type      0 (inode node)
[    8.542669@3]        group_type     0 (no node group)
[    8.547154@3]        sqnum          902817
[    8.550689@3]        len            64
[    8.553881@3]        key            (0, inode)
[    8.557761@3]        creat_sqnum    1897141343029821440
[    8.562417@3]        size           0
[    8.565522@3]        nlink          0
[    8.568621@3]        atime          -2702734863953297408.28
[    8.573631@3]        mtime          0.1956
[    8.577160@3]        ctime          8547360110304827441.5
[    8.581997@3]        uid            0
[    8.585095@3]        gid            0
[    8.588207@3]        mode           0
[    8.591311@3]        flags          0x0
[    8.594588@3]        xattr_cnt      0
[    8.597695@3]        xattr_size     0
[    8.600792@3]        xattr_names    0
[    8.603904@3]        compr_type     0x0
[    8.607181@3]        data len       0
[    8.610420@3] UBIFS error (ubi0:0 pid 963): ubifs_scanned_corruption: corruption at LEB 4:2048
[    8.618835@3] UBIFS error (ubi0:0 pid 963): ubifs_scanned_corruption: first 8192 bytes from LEB 4:2048
[    8.630445@3] UBIFS error (ubi0:0 pid 963): ubifs_recover_leb: LEB 4 scanning failed
[    8.643114@1] name: deviceid, size 15
[    8.646565@3] name: didkey, size 39
[    8.659145@2] name: mac_wifi, size 17
[    8.662506@0] name: mac_bt, size 17
[    9.021202@1] name: mac_wifi, size 17
BusyBox v1.27.2 () built-in shell (ash)
_____  _              _____  ___    ___  _____
|     ||_| ___  ___   |   __||_  |  |_  ||  _  |
| | | || ||  _|| . |  |__   | _| |_ |  _||     |
|_|_|_||_||___||___|  |_____||_____||___||__|__|
    Reboot (SNAPSHOT, 70-1-1)
=== WARNING! =====================================
There is no root password defined on this device!
Use the "passwd" command to set up a new password
in order to prevent unauthorized SSH logins.
root@mico:/#
GMT+8, 2025-9-14 03:12 , Processed in 0.521776 second(s), 19 queries , MemCached On.
