楼主: zwbjsnt
[新奇玩法] 终于完美解决了小米人体传感器2分钟的限制
 火.. [复制链接]
发表于 2020-3-3 13:21:49 | 显示全部楼层
killadm 发表于 2020-3-1 00:55
感谢分享,家里的人体全改了
ha只能通过修改官方组件解决了
你好,请问有详细点教程吗?
 楼主| 发表于 2020-3-3 13:38:34 来自手机 | 显示全部楼层
智能家居 发表于 2020-3-3 11:54
楼主,请问一下,改完之后,on-off能由原来的2分钟减少到5秒吗?
可以,在ha里的状态还是要用z2m模块接入
 楼主| 发表于 2020-3-3 15:28:19 | 显示全部楼层
是的,配合Z2M网关
发表于 2020-3-4 10:56:25 | 显示全部楼层
智能家居 发表于 2020-3-3 13:21
你好,请问有详细点教程吗?
我用小米网关还是有问题,准备换z2m
 楼主| 发表于 2020-3-4 11:03:41 | 显示全部楼层
killadm 发表于 2020-3-4 10:56
我用小米网关还是有问题,准备换z2m
是的,只能z2m
发表于 2020-3-23 12:23:03 | 显示全部楼层
设置 no_occupancy_since: [5, 5] occupancy_timeout: 5 之后 看z2m日志还是一秒钟出好几条报告 可能是什么问题
 楼主| 发表于 2020-3-25 18:21:58 | 显示全部楼层
linoul 发表于 2020-3-23 12:23
设置 no_occupancy_since: [5, 5] occupancy_timeout: 5 之后 看z2m日志还是一秒钟出好几条报告 可能是什么 ...
日志贴出来看看
发表于 2020-3-26 14:09:49 | 显示全部楼层
zwbjsnt 发表于 2020-3-25 18:21
日志贴出来看看
zigbee2mqtt:info  2020-03-26 13:18:10: MQTT publish: topic 'zigbee2mqtt/0x00158d0001b754a6', payload '{"battery":100,"voltage":3005,"illuminance":21,"illuminance_lux":21,"linkquality":70,"occupancy":false}'
zigbee2mqtt:info  2020-03-26 13:18:10: MQTT publish: topic 'zigbee2mqtt/0x00158d0001b754a6', payload '{"battery":100,"voltage":3005,"illuminance":21,"illuminance_lux":21,"linkquality":70,"occupancy":true}'
zigbee2mqtt:info  2020-03-26 13:18:15: MQTT publish: topic 'zigbee2mqtt/0x00158d0001b754a6', payload '{"battery":100,"voltage":3005,"illuminance":21,"illuminance_lux":21,"linkquality":70,"occupancy":false}'
zigbee2mqtt:info  2020-03-26 13:18:15: MQTT publish: topic 'zigbee2mqtt/0x00158d0001b754a6', payload '{"battery":100,"voltage":3005,"illuminance":27,"illuminance_lux":27,"linkquality":68,"occupancy":false}'
zigbee2mqtt:info  2020-03-26 13:18:15: MQTT publish: topic 'zigbee2mqtt/0x00158d0001b754a6', payload '{"battery":100,"voltage":3005,"illuminance":27,"illuminance_lux":27,"linkquality":68,"occupancy":true}'
zigbee2mqtt:info  2020-03-26 13:18:20: MQTT publish: topic 'zigbee2mqtt/0x00158d0001b754a6', payload '{"battery":100,"voltage":3005,"illuminance":27,"illuminance_lux":27,"linkquality":68,"occupancy":false}'
设备设置了以下参数occupancy_timeout: 5
 楼主| 发表于 2020-3-26 23:00:00 | 显示全部楼层
好像是这样的,不影响正常使用
发表于 2020-4-7 15:28:08 | 显示全部楼层
是必须要 z2m + 短接吗, 看文档不短接只是2分钟变成1分钟?
GMT+8, 2025-9-13 03:29 , Processed in 0.058413 second(s), 11 queries , MemCached On.
