楼主: a2633063
[进阶教程] 斐讯M1 A1 TC1 DC1刷机连接mqtt 带app
发表于 2024-3-8 23:46:21 | 显示全部楼层
M1接入HA后没有设备和实体信息,配置文件存放路径/config/packages/phicomm_aircat.yaml 配置文件信息如下:
##mqtt-空气检测仪##
## 以下内容中,请将MACMAC替换为你的排插的mac地址,不带冒号,全部小写,如123456789abc
## https://github.com/a2633063/zM1/ ... t%E6%8E%A5%E5%85%A5
mqtt:
    - name: 'zm1_已换成实际mac_temperature'
      state_topic: 'device/zm1/已换成实际mac/sensor'
      unique_id: zm1_已换成实际mac_temperature
      unit_of_measurement: '°C'
      icon: 'mdi:thermometer'
      value_template: '{{ value_json.temperature }}'
    - name: 'zm1_已换成实际mac_humidity'
      unique_id: zm1_已换成实际mac_humidity
      unit_of_measurement: '%'
      icon: mdi:water-percent
      value_template: '{{ value_json.humidity }}'
    - name: 'zm1_已换成实际mac_pm25'
      unique_id: zm1_已换成实际mac_pm25
      unit_of_measurement: 'μg/m³'
      icon: mdi:blur
      value_template: '{{ value_json.PM25 }}'
    - name: 'zm1_已换成实际mac_hcho'
      unique_id: zm1_已换成实际mac_hcho
      unit_of_measurement: 'mg/m³'
      icon: mdi:chemical-weapon
      value_template: '{{ value_json.formaldehyde }}'
  light:
    - name: zm1_已换成实际mac_brightness
      unique_id: zm1_已换成实际mac_brightness
      schema: template
      command_topic: "device/zm1/已换成实际mac/set"
      state_topic: "device/zm1/已换成实际mac/state"
      command_on_template: >
        {"mac": "已换成实际mac"
        {%- if brightness is defined -%}
        , "brightness": {{ ((brightness-1) / 64 )|int +1 }}
        {%- else -%}
        , "brightness": 4
        {%- endif -%}
      command_off_template: '{"mac": "已换成实际mac", "brightness": 0}'
      state_template: >
        {%- if value_json.brightness == 0 -%}
          off
        {%- else -%}
          on
        {%- endif -%}
      brightness_template: >
        {%- if value_json.brightness is defined -%}
          {{ ( value_json.brightness *64 )|int }}
        {%- endif -%}
homeassistant:
  customize:
    light.zm1_已换成实际mac_brightness:
      friendly_name: zM1亮度
    sensor.zm1_已换成实际mac_temperature:
      friendly_name: zM1温度
    sensor.zm1_已换成实际mac_humidity:
      friendly_name: zM1湿度
    sensor.zm1_已换成实际mac_pm25:
      friendly_name: zM1 PM2.5
    sensor.zm1_已换成实际mac_hcho:
      friendly_name: zM1甲醛
在楼主的APP客户端上可以正常通过mqtt通信,我的HACore版本是2024.3.0,哪位大佬帮忙看一下,非常感谢。
 楼主| 发表于 2024-3-15 15:12:54 | 显示全部楼层
freedomqq 发表于 2024-3-8 23:46
M1接入HA后没有设备和实体信息,配置文件存放路径/config/packages/phicomm_aircat.yaml 配置文件信息如下 ...
确认ha配置了mqtt   确认配置了packages   看看ha里配置检查是否输出了什么错误信息
发表于 2024-3-27 18:08:42 | 显示全部楼层
刷机中,学习
发表于 2024-4-5 21:03:21 | 显示全部楼层
感谢大牛分享
发表于 2024-12-26 15:14:56 | 显示全部楼层
感谢大佬,支持大佬
发表于 2025-2-8 15:14:45 | 显示全部楼层
学习了,谢谢
发表于 2025-3-9 21:46:23 | 显示全部楼层
一直把它当普通排插用了,哪天写下试试,提前感谢了
GMT+8, 2025-9-13 03:25 , Processed in 0.343617 second(s), 12 queries , MemCached On.
