楼主: a2633063
[进阶教程] 斐讯M1 A1 TC1 DC1刷机连接mqtt 带app
maxg 手机认证
发表于 2022-8-24 10:19:06 | 显示全部楼层
zM1固件刷不成功,一直卡在40%不动了,每次是都这样,请教是什么问题导致的
 楼主| 发表于 2022-8-25 15:11:06 | 显示全部楼层
maxg 发表于 2022-8-24 10:19
zM1固件刷不成功,一直卡在40%不动了,每次是都这样,请教是什么问题导致的 ...
M1是除了wifi模块负责网络通信 还有个主控负责传感器的数据收集
中控采集传感器数据后通过串口发给wifi模块 wifi模块将此数据用wifi发出
而这个串口和刷机的串口是同一个串口,  所以在用ttl给wifi刷机时如果正好主控通过串口发了一组数据 就会导致和刷机的数据冲突,导致刷机失败.  如果在刷机过程中主控一直没有发送串口数据,不会有干扰就可以刷机成功.
因此ttl刷机会有大概率刷机失败.
建议jlink刷机
发表于 2022-11-25 11:02:18 | 显示全部楼层
感谢贡献并分享,M1刷机并接入ha成功. 考虑再入手几个玩下
ha更新了mqtt格式,略做调整后自用模板,MACMAC也需替换
# Example configuration.yaml entry
mqtt:
    - name: 'zm1_MACMAC_temperature'
      unique_id: zm1_MACMAC_temperature
      # friendly_name: 温度
      state_topic: 'device/zm1/MACMAC/sensor'
      icon: 'mdi:thermometer'
      unit_of_measurement: '°C'
      value_template: '{{ value_json.temperature }}'
    - name: 'zm1_MACMAC_humidity'
      unique_id: zm1_MACMAC_humidity
      # friendly_name: 湿度
      icon: mdi:water-percent
      unit_of_measurement: '%'
      value_template: '{{ value_json.humidity }}'
    - name: 'zm1_MACMAC_pm25'
      unique_id: zm1_MACMAC_pm25
      # friendly_name: PM25
      icon: mdi:blur
      unit_of_measurement: 'μg/m³'
      value_template: '{{ value_json.PM25 }}'
    - name: 'zm1_MACMAC_hcho'
      unique_id: zm1_MACMAC_hcho
      # friendly_name: 甲醛
      unit_of_measurement: 'mg/m³'
      icon: mdi:chemical-weapon
      value_template: '{{ value_json.formaldehyde }}'
  light:
    - name: zm1_MACMAC_brightness
      unique_id: zm1_MACMAC_brightness
      schema: template
      command_topic: "device/zm1/MACMAC/set"
      state_topic: "device/zm1/MACMAC/state"
      command_on_template: >
        {"mac": "MACMAC"
        {%- if brightness is defined -%}
        , "brightness": {{ ((brightness-1) / 64 )|int +1 }}
        {%- else -%}
        , "brightness": 4
        {%- endif -%}
      command_off_template: '{"mac": "MACMAC", "brightness": 0}'
      state_template: >
        {%- if value_json.brightness == 0 -%}
          off
        {%- else -%}
          on
        {%- endif -%}
      brightness_template: >
        {%- if value_json.brightness is defined -%}
          {{ ( value_json.brightness *64 )|int }}
        {%- endif -%}
发表于 2023-2-11 16:01:18 | 显示全部楼层
大神,谢谢贡献
发表于 2023-3-17 18:00:16 | 显示全部楼层
老哥,现在的zm1固件支持中文wifi了吗?
发表于 2023-6-16 09:26:16 | 显示全部楼层
感谢分享,前来支持
发表于 2023-11-18 12:38:04 | 显示全部楼层
支持一下
发表于 2023-11-26 16:59:49 | 显示全部楼层
alanshu 发表于 2022-2-19 20:39
完美刷机完成。
HA里完美,Homekit里温度和PM2.5正常,但是湿度不显示,找原因中。
谢谢,已star.   ...
我的是 湿度 甲醛都不显示,请问你怎么解决的?是不是cofig格式有问题?
发表于 2023-12-1 22:03:45 | 显示全部楼层
记得就是配置文件的问题
发表于 2023-12-26 23:21:13 | 显示全部楼层
之前刷好了一直正常,用了一年多,现在重新换手机装新APP,发现能控制亮度,不显示数据了,在APP里。(更新app后正常了)
GMT+8, 2025-9-11 03:40 , Processed in 0.447600 second(s), 14 queries , MemCached On.
