查看: 128158|回复: 208
[插件集成] 小米万能遥控 格力空调插件
教程狂人论坛风云人物突出贡献
发表于 2017-8-16 21:03:49 | 显示全部楼层 |阅读模式
小米万能遥控器【创米万能遥控】代码来源:https://github.com/SchumyHao/cus ... itch/chuangmi_ir.py
适用于格力空调,遥控器型号YB0F2
空调控制部分代码参考了菲神的代码【仰望着天空,抄袭了一遍代码】
依赖需求:
1、需要python-miio
2、要学红外码的要装妖神的,chuangmi_ir.py3、有另一个以python-mirobo为核心的版本的chuangmi_ir.py https://github.com/syssi/chuangmi_ir【用法跟妖神的一模一样】
climate:
  - platform: gree
    host: 192.168.2.205
    token: 你的token
    target_temp: 27
    target_sensor: sensor.caiyun_realtime_temperature
target_sensor:这里填你的室内温度传感器的entity_id
使用方法:
下载解压,复制到相应文件夹
楼主的格力空调遥控器型号是YB0F2,如果你的也是。可以直接用。否则,需要自行学红外码复制进去。因楼主的空调没有制热功能,因此没有学制热的红外码。红外码在gree.py 第314行 到328行
def _sendpacket(self,retry=2):
        """Send packet to device."""
        cool = ("Z6WLAAkCAACnAgAASwYAAGARAAAqIwAA100AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0IQEBIQEBAQEBAQEBAQEBAQEBAQEBISEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBIQEB",
"Z6WLABcCAACZAgAAXAYAAGIRAAAoIwAA3k0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0IQEBIQEBAQEhAQEBAQEBAQEBAQEBISEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhIQEB",
"Z6WLADUCAAB7AgAAegYAAIERAAAIIwAA+00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0IQEBIQEBAQEBIQEBAQEBAQEBAQEBISEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhIQEB",
"Z6WLADUCAAB7AgAAegYAAIERAAAIIwAA+00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0IQEBIQEBAQEhIQEBAQEBAQEBAQEBISEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBASEB",
"Z6WLABoCAACWAgAAXwYAAGYRAAAjIwAA300AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0IQEBIQEBAQEBASEBAQEBAQEBAQEBISEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBASEB",
"Z6WLAAQCAACrAgAASgYAAF8RAAAqIwAA100AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0IQEBIQEBAQEhASEBAQEBAQEBAQEBISEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhASEB",
"Z6WLADUCAAB7AgAAegYAAIERAAAIIwAA+U0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0IQEBIQEBAQEBISEBAQEBAQEBAQEBISEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhASEB",
"Z6WLAAwCAACkAgAAUgYAAEYRAABCIwAAwU0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0IQEBIQEBAQEhISEBAQEBAQEBAQEBISEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBISEB",
"Z6WLAA8CAACiAgAAUQYAAGERAAApIwAA2E0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0IQEBIQEBAQEBAQEhAQEBAQEBAQEBISEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBISEB",
"Z6WLABQCAACcAgAAWwYAAGERAAAoIwAA2k0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0IQEBIQEBAQEhAQEhAQEBAQEBAQEBISEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhISEB",
"Z6WLABYCAACaAgAAWwYAAGIRAAAnIwAA200AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0IQEBIQEBAQEBIQEhAQEBAQEBAQEBISEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhISEB",
"Z6WLABICAACeAgAAVwYAAGARAAApIwAA2k0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0IQEBIQEBAQEhIQEhAQEBAQEBAQEBISEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEBAQEB",
"Z6WLABMCAACdAgAAVwYAAGERAAAnIwAA2k0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0IQEBIQEBAQEBASEhAQEBAQEBAQEBISEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEBAQEB",
"Z6WLABQCAACcAgAAWgYAAGERAAAnIwAA2k0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0IQEBIQEBAQEhASEhAQEBAQEBAQEBISEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBAQEhAQEB",
"Z6WLABUCAACbAgAAWwYAAGERAAAnIwAA200AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0IQEBIQEBAQEBISEhAQEBAQEBAQEBISEBAQEBASEBIQEBIQFRAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBAQEBASEhAQEB"
分别是16度制冷风速自动  到 30度制冷风速自动。
37楼有美的的遥控码,需要的去复制替换下。
2017年11月18日更新:
将miio替换为更广泛使用的 mirobo
climate.zip (21.15 KB, 下载次数: 201)
参与人数 2金钱 +16 收起 理由
27hh + 10 感谢及时更新mirobo!
+ 6 6到不行
Freddy.
最佳新人卓越贡献
发表于 2017-8-16 21:06:23 | 显示全部楼层
老规矩 抢沙发!!!
教程狂人论坛风云人物突出贡献
 楼主| 发表于 2017-8-16 21:07:05 | 显示全部楼层
好专业啊,你抢我沙发好几回了
发表于 2017-8-16 21:07:09 | 显示全部楼层
谢谢分享!!!
发表于 2017-8-16 21:09:32 | 显示全部楼层
我要像天一样高,一样高傲奥~
发表于 2017-8-16 21:10:03 | 显示全部楼层
学习学习,谢谢分享
教程狂人论坛风云人物突出贡献
 楼主| 发表于 2017-8-16 21:10:10 | 显示全部楼层
Jones 发表于 2017-8-16 21:09
我要像天一样高,一样高傲奥~
我还在等你的红外sonoff
发表于 2017-8-16 21:39:10 | 显示全部楼层
感谢楼主分享
wqqs 手机认证
活跃会员
发表于 2017-8-17 01:01:10 | 显示全部楼层
好东西,谢谢分享
发表于 2017-8-17 08:31:58 | 显示全部楼层
支持啊~~~自己半吊子不知道怎么从菲神的博联移到小米~~~~~~~真好
GMT+8, 2026-1-3 13:12 , Processed in 0.470905 second(s), 11 queries , MemCached On.
