楼主: goto100
[插件集成] 终于搞定了格力云控,控制中央空调【局域网协议】
 火.. [复制链接]
发表于 2022-5-12 04:03:25 | 显示全部楼层
qiaoqiao1235 发表于 2022-4-7 22:05
2022.4.0 fan类有一些变化,会起不来。fork了一下做了些适配,同时支持自定义温度传感器,支持通过HACS自 ...
日志如下
2022-05-12 03:51:46 INFO (MainThread) [custom_components.gree2.climate] Setting up Gree climate platform
2022-05-12 03:51:46 INFO (MainThread) [custom_components.gree2.climate] scan_broadcast
2022-05-12 03:51:46 INFO (MainThread) [custom_components.gree2.climate] socket send data {'t': 'scan'} to <broadcast>
2022-05-12 03:51:46 INFO (Thread-3) [custom_components.gree2.climate] socket received from ('192.168.3.102', 7000):{"t":"pack","i":1,"uid":0,"cid":"502cc688649e","tcid":"","pack":"LP24Ek0OaYogxs3iQLjL4DSECHCog2nThcgqigsKDTFYT1PXPBDouOPiWHaG4G8lz22fUZtUbkblUYF5BzlKDV9xeQzMlsaP4RKBtrnsDrMqgYfZO4+mpxkRPw5ZdvUFqWiTgGkoXDxunmUMdG7sp/aOGxc0vwxgjIcGCxHsPhR9lIrFz1NNYVMSrt8ChbhRUgEZnR87H5dIVewkCjMlC6n+/sB6g39ps/bszRb9no2vwosJlmZ9sWYMTM53/iMOYbVT1KxU0l8Qx3oYI78n9w=="}
2022-05-12 03:51:46 INFO (Thread-3) [custom_components.gree2.climate] Server received pack {'t': 'dev', 'cid': '502cc688649e', 'bc': 'gree', 'brand': 'gree', 'catalog': 'gree', 'mac': '502cc688649e', 'mid': '60', 'model': 'gree', 'name': 'c688649e', 'series': 'gree', 'vender': '1', 'ver': 'V1.1.0.0', 'lock': 0, 'subCnt': 4}
2022-05-12 03:51:46 INFO (Thread-3) [custom_components.gree2.climate] socket send pack {'mac': '502cc688649e', 't': 'bind', 'uid': 0} to 192.168.3.102
2022-05-12 03:51:46 INFO (Thread-3) [custom_components.gree2.climate] socket send data {'cid': 'app', 'i': 1, 't': 'pack', 'uid': 0, 'pack': 'hlKu1K7/q99dssmmJxMz706KKmM8CvuqIGoC2kMyaHSj9mrs/0p7GUTdWxmNaBUt'} to 192.168.3.102
好像只发现了一台设备?实体和卡片里都没有
发表于 2022-5-13 15:15:11 | 显示全部楼层
w2968066 发表于 2022-5-11 04:25
大佬请问我放入custom_components文件夹后集成里面死活搜不到怎么办,docker安装的,UI和容器都重启过, ...
在config下创建climate.yaml
- platform: greeCentral
再在configuration.yaml中加上配置:
climate: !include climate.yaml
发表于 2022-5-13 15:22:00 | 显示全部楼层
w2968066 发表于 2022-5-12 04:03
日志如下
2022-05-12 03:51:46 INFO (MainThread) [custom_components.gree2.climate] Setting up Gree c ...
是二代的吗?二代可能不支持,可以看看原作者的最新提交,似乎尝试支持了二代
发表于 2022-5-13 15:49:02 | 显示全部楼层
是二代,也是这么配置的。。原作者的也试过,Platform error climate.gree2 - cannot import name 'SPEED_HIGH' from 'homeassistant.components.fan' (/usr/src/homeassistant/homeassistant/components/fan/__init__.py)”   报这个错无法重启。好像是有啥冲突但是我不太懂。
发表于 2022-5-13 21:03:48 | 显示全部楼层
w2968066 发表于 2022-5-13 15:49
是二代,也是这么配置的。。原作者的也试过,Platform error climate.gree2 - cannot import name 'SPEED ...
二代我在论坛没见到成功的……
发表于 2022-5-14 02:32:51 | 显示全部楼层
qiaoqiao1235 发表于 2022-5-13 21:03
二代我在论坛没见到成功的……
这就尴尬了。那还不如上一代?
发表于 2022-5-14 02:53:01 | 显示全部楼层
二代我在论坛没见到成功的……
https://github.com/maxmib/Ha-GreeCentralClimate  我搞定了。用这个大佬的。完美。。感谢
发表于 2022-5-22 23:02:52 | 显示全部楼层
在集成中gree climate 可以找到一个设备,5个实体,但控制中fresh air, panel light ,quiet, xfan
都 是灰色的。无法打开。配置,集成中一个实体状态都是不可用
发表于 2022-5-23 11:07:27 | 显示全部楼层
请楼主回复一下谢谢
发表于 2022-6-21 07:27:16 | 显示全部楼层
研究不明白
GMT+8, 2025-9-21 06:42 , Processed in 1.265246 second(s), 7 queries , MemCached On.
