楼主: jiluxinqing
[新奇玩法] 全新QQ邮件通知功能【2020-6-11更新】
发表于 2020-3-14 11:38:38 | 显示全部楼层
调用不成功,不知道那里错了
发表于 2020-3-14 11:40:43 | 显示全部楼层
2020-03-14 11:36:24 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2511835632] local variable 'msg' referenced before assignment
  File "/usr/local/python3/lib/python3.6/site-packages/homeassistant/components/websocket_api/commands.py", line 133, in handle_call_service
    connection.context(msg),
  File "/usr/local/python3/lib/python3.6/site-packages/homeassistant/core.py", line 1235, in async_call
    await asyncio.shield(self._execute_service(handler, service_call))
  File "/usr/local/python3/lib/python3.6/asyncio/futures.py", line 331, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/local/python3/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
    future.result()
  File "/usr/local/python3/lib/python3.6/asyncio/futures.py", line 244, in result
    raise self._exception
  File "/usr/local/python3/lib/python3.6/asyncio/tasks.py", line 181, in _step
    result = coro.throw(exc)
  File "/usr/local/python3/lib/python3.6/site-packages/homeassistant/core.py", line 1262, in _execute_service
    await self._hass.async_add_executor_job(handler.func, service_call)
    future.result()
  File "/usr/local/python3/lib/python3.6/concurrent/futures/thread.py", line 55, in run
  File "/config/custom_components/ha_qqmail/__init__.py", line 95, in notify
    _message = self.api_msg.default(_message, _entity, _action, hass.config.api.base_url.strip('/') + URL)
  File "/config/custom_components/ha_qqmail/api_msg.py", line 23, in default
    if entity is None and action is None:
UnboundLocalError: local variable 'msg' referenced before assignment
一直报msg不是没有声明?需怎么声明一下?
发表于 2020-3-14 12:00:06 | 显示全部楼层
coriding 发表于 2020-3-14 11:40
2020-03-14 11:36:24 ERROR (MainThread) [homeassistant.components.websocket_api.http.connect ..
自己读了一下api_msg.py发现,其中使用了msg 但是参数传递却不是使用该参数,而是应该使用title
因此将楼主代码修改了一点点
api_msg.py中的所有
    return self.template(msg)
    #替换为下面的内容
    return self.template(title)
问题解决,测试成功!
感谢楼主大大!
 楼主| 发表于 2020-3-14 12:55:09 | 显示全部楼层
coriding 发表于 2020-3-14 12:00
[md]
自己读了一下`api_msg.py`发现,其中使用了`msg` 但是参数传递却不是使用该参数,而是应该使用`titl ...
写的时候没有测试
http://github.com/shaonianzhentan
发表于 2020-3-14 23:42:09 | 显示全部楼层
学习一下
发表于 2020-4-10 15:46:32 | 显示全部楼层
全新QQ邮件通知功能【2020-1-5更新】 [修改]
高级模式
发表于 2020-5-15 21:18:11 | 显示全部楼层
学习一下
发表于 2020-5-27 21:38:32 | 显示全部楼层
hacs.json这个文件放在哪里啊?
发表于 2020-11-15 20:16:40 | 显示全部楼层
karl_31 发表于 2019-11-24 17:25
学习一下,谢谢分享
学习一下,谢谢分享
发表于 2020-11-17 08:32:18 | 显示全部楼层
学习一下,谢谢分享
GMT+8, 2025-9-13 03:23 , Processed in 0.448049 second(s), 12 queries , MemCached On.
